Laminova's Bone Dry Or Wet And Gritty....?
#41
Posted 14 August 2017 - 08:43 AM
#42
Posted 15 August 2017 - 07:01 AM
#43
Posted 15 August 2017 - 08:38 PM
#44
Posted 15 August 2017 - 09:26 PM
Edited by CHILL Gone DUTCH, 15 August 2017 - 09:27 PM.
#45
Posted 15 August 2017 - 09:29 PM
#46
Posted 16 August 2017 - 06:26 AM
Hmm, tank level has dropped 100 ml. I'm hoping this is air in the system an it's not still leaking. I put a smear of red rubber grease on the o rings before fitting. Any thoughts on this being sufficient or not? Vocky?
they can leak for a number of reasons - seals failing, cores dented by pliers, etc
I would advise you use some form of sealant on them if the cores are damaged by pliers, or replace the failing O ring seals
I once had a brand new inlet manifold leak, upon opening it up I found they had swapped the cores with an old manifold and the cores were dented by pliers
#47
Posted 16 August 2017 - 11:23 AM
#48
Posted 16 August 2017 - 02:07 PM
My engine was putting out a reasonable amount of white smoke after rebuild, and sure enough (think Vocky diagnosed it), at least one of the laminova seals was leaking, despite careful rebuild of the manifold. New O-rings solved it (well lubricated on the way in..).
#49
Posted 17 August 2017 - 03:47 PM
moral of the story is always lube your o ring before you insert anything
#50
Posted 18 August 2017 - 08:38 AM
