Anyone Still Running A Pioneer Ts-Wx11A Subwoofer?
...need power socket pin outs
2 replies to this topic
#1 H1 HWK
H1 HWK
  • 1,009 posts
Posted 17 August 2012 - 09:50 PM
Evening All, Recently picked up a Pioneer TS-WX11A compact amplified sub woofer, as I have seen a few members on here rate them over the years. Purchased from a well known auction site, but without the wiring looms. My head unit can do all the bits (LPF/gain etc) so I wasn't worried about the lack of accessories/wiring.....how hard can it be I thought to myself ? - a ground, +12 feed, +12 switched and some speaker inputs right? Unfortunately there are no markings on the outside of the connector port and apart from tracing the +12v and grnd feed to the internal amp after cracking it open, I can't work out which is the accessory switching input and which are the audio inputs as all the internal wire gauge is the same :wacko: Not keen on dumping 12v across the audio inputs while guessing the inputs. I've checked the manual and there is no help there, phoned Pioneer cust support this afternoon and they were really good and gave me the part of the loom (TXH1614) and passed me onto their spares distribution peeps on 08445 572510, but unfortunately they couldn't help me source one. Like wise Pioneer Tech support's documentation didn't cover the pin outs :( It's a polarised Molex 8 way dual in line connector (not the RJ45 remote control one). If anyone still has one of these in use (or maybe the newer WX10A) could you post me up a pic or a description of your wiring config so that I can try and get this little box kicking? Thanks all - enjoy the weekend :drink:
#2 DEKKER
DEKKER
  • 562 posts
  • Interests:F1 , Trance , part time boob inspector but mostly into leg appreciation.
Posted 19 August 2012 - 03:00 AM
Hi , yes I have 2 of them behind the seats . online manual and wiring can be found here .
http://docs.pioneer....TRD1287_manual/
#3 H1 HWK
H1 HWK
  • 1,009 posts
Posted 19 August 2012 - 07:35 AM
Hi Dekker, thanks for the info, but I don't have the original loom to know which wires (i.e. which pin is switched live, and which pins are the L & R audio inputs). Any chance you could post me up a picture of the connector block on one of yours and I can try to work it out from that? By the way do you find them any good in your setup? Thanks.
