#21
Posted 07 February 2013 - 11:36 AM
#22
Posted 07 February 2013 - 11:40 AM
#23
Posted 24 March 2013 - 10:52 PM
#24
Posted 22 April 2013 - 08:19 AM
Paint and fit V (Cheers Joe_589!) DONE
Plastidipped, drilled and cable tied on discreetly.
Fit new side grills (Cheers Cocopops!) DONE
Fitted
Fit tat diffuser (Cheers JG!) DONE
Fitted and looks the business
Remove and clean wheels properly DONE
Removed washed properly, polished and waxed, also fitted new centrecaps.
Investigate stiff steering DONE
Down to Nitron Quick Rack can remove and adjust by the looks of it but I'm used to it now. No fault, just different.
General steering and suspension inspection on each corner (with shocks removed to allow easier pulling, lifting and shoogling) DONE
No leaks or play in components. Has had new wishbone on rear after having the Gaz shock dent. Ball joints upfront have been changed. Generally looks used but in good shape.
Brakes inspection (check for uneven wear, leaking seals etc. Possibly bleed) DONE
Fluid changed by Murray Lotus. Was still not happy with feel. Discs and pads quite worn. Replaced discs and pads and voila awesome brakes. Very happy with the brakes. Standard discs with M1144 pads all round.
Oil and filter change DONE
Shell Helix Ultra 5w30
Replace dead side light bulb DONE
Replaced and connections tighted up on holder
Book Geo check/fix (don't think I'm happy with the geo atm) DONE
340r Road settings done by jtj30 (Ladybank Tyres) Very Nice! Front camber needed adjustment then toe adjustments all round. Could really do with going back and doing Castor but feels awesome at the moment.
Interior
Seats and mats out, proper clean inside.DONE
Fit 10cm speakers in dash DONE
Sony Xplod
Replace current rear speakers. DONE
Sony Xplod
#25
Posted 22 April 2013 - 08:23 AM
#26
Posted 22 April 2013 - 08:27 AM
#27
Posted 22 April 2013 - 08:30 AM
Most recent
#28
Posted 22 April 2013 - 08:46 AM
Seriously pondering selling the beast post Hoon and Monaco (End of May)
Got my pre and post mixed up there!!
#29
Posted 15 December 2013 - 07:09 PM
#30
Posted 19 December 2013 - 10:07 AM
Normal shims are 1.5mm...my set from Elise Parts are 2mm and 1mm
So normally with 3-1 it'd be 4.5mm front and 1.5mm back.
Looks like I'm going to be .5mm out at least.
Why the chuff don't they just supply them in 1.5mm as per OEM?
#31
Posted 23 December 2013 - 11:03 AM
Doing the suspension refresh, 3 corners done now. Well past the "wish I never fcuking started this" stage. Buying p clips online now to replace all the shagged ones, a million of my centre undertray bolts seem to have gone awal. I had to grind the bolts off the front undertray. Don't get me started on splitting the bastard ball joints. I have a mashed hand to show for that.
Buying new handbrake cable too.
All in all, a highly recommended piece of work.
Uggh!
#32
Posted 23 December 2013 - 08:44 PM
#33
Posted 07 January 2014 - 04:48 PM
#34
Posted 07 January 2014 - 04:49 PM
I think I have a Naca duct sitting around somewhere. Are they expensive?
#35
Posted 07 January 2014 - 04:52 PM
#36
Posted 07 January 2014 - 05:29 PM
Who is doing the bodywork? Think I'll get mine sorted asap.
#37
Posted 07 January 2014 - 05:33 PM
#38
Posted 07 January 2014 - 05:37 PM
#39
Posted 07 January 2014 - 05:54 PM
Missing a gouge from centre to middle of N/S headlamp after hitting dog.
Edited by LY_Scott, 07 January 2014 - 05:55 PM.
#40
Posted 07 January 2014 - 05:57 PM
Cheers Scott, I'll get in touch with him.
