Stack 52mm boost and oil temperature gauges mounted in a Hurricane gauge holder from Elise-shop. I like the look, almost like a factory accessory.
Boost gauge has electrical stepper motor and a map sensor mounted on the firewall in front of the intercooler.
Wiring for the gauges is wound with Tesa cable wrap tape, same as wiring loom from the factory. Had to run the wiring over the tank to clear the cup holder.
