Supercharger Noise Question
13 replies to this topic
#1 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 01 September 2012 - 05:07 PM
Just curious about this... From footage I've seen, it seems the supercharger whine noise seems to vary in loudness with throttle opening / engine load rather than just simply with revs. Just wondered why this is, as I had assumed that since the charger is driven directly from engine crank it'd be doing the same thing at, say 4k rpm small throttle opening and 4k rpm wide open throttle? (ie producing same boost). I'm missing something and curious to know the answer. Cheers.
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 01 September 2012 - 05:18 PM
This is correct. If you drive at half throttle or at cruise you would never know. I think it's down to airflow, ie in your example the rotors spin the same at 4k but on full throttle they will grab max air as throttle butterfly will be fully open.
#3 Bargi
Bargi
  • 4,483 posts
Posted 01 September 2012 - 05:53 PM
It's the load on the engine, more load more noise . if you sit there and review it in neutral you get very little whine.
#4 slindborg
Posted 01 September 2012 - 05:57 PM
Load = torque demand. = air flow = noise if you have an intake setup for that.
#5 OneYet
OneYet
  • 1,355 posts
Posted 01 September 2012 - 06:41 PM
If I would use my original airbox. Would the noise/whine levels go down?
#6 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 01 September 2012 - 06:54 PM
Yes, considerably
#7 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 01 September 2012 - 08:01 PM
Ah. So hadn't realised the throttle butterfly is upstream of the compressor. If so I can see that at small throttle opening there is less air pressure feeding the compressor so it's doing less work. At open throttle its got full atmospheric pressure feeding it so is blowing more air, under more load and so making more noise. A bit like covering the air intake of a hair dryer (bear with me). If you do its revs increase indicating reduced load on the fan. Is that right?
#8 slindborg
Posted 01 September 2012 - 08:13 PM
Other way round.
#9 OneYet
OneYet
  • 1,355 posts
Posted 01 September 2012 - 08:30 PM
Yes, considerably
A project for the winter then.
#10 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 01 September 2012 - 08:49 PM
Other way round.
Yes I see. Cheers.
#11 Rosssco
Rosssco
  • 4,185 posts
Posted 02 September 2012 - 07:46 AM
The SC uses a bypass valve that directs air through a bypass channel at idle and low throttle demand, which effectively allows the rotors to 'free wheel'. This reduces SC load on the engine when not required / increases efficiency. The SC doesn't create any whine when operating in this way. Theres an animation on YouTube showing this..
#12 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 02 September 2012 - 09:40 AM
Another reason why some are louder then others is because some supercharged vxs are stage 3 and others are stage 2. With stage 3 you have to fit a smaller pulley which is alot louder then what a stage 2 pulley is.
#13 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 02 September 2012 - 08:28 PM
You are also watching a video on YouTube no doubt, from experience the whine is absolutely nowhere near as annoying as on the videos, from the one I saw on YouTube I would have never gone for the conversion. Go out in one they don't sound bad. Out of interest, is stage 3 possible with a standard airbox, or would this cause a big air restriction?
#14 Anarchy
Anarchy
  • 2,237 posts
Posted 03 September 2012 - 06:52 PM
I was quite surprised how noisy it was with a standard airbox but with the bottom cut off. Now I am used to it a bit more noise would be acceptable.
