Mmg Stage 4 (Dastek Dyno Results)
Posted 04 September 2012 - 01:55 PM
Posted 04 September 2012 - 02:02 PM
Posted 04 September 2012 - 02:04 PM
Posted 04 September 2012 - 02:06 PM
Good result, stick the graph up. Seems like a very generous rolling road to me though with you 2.5 inch exhaust. No wonder your brothers s2000 makes so much power
My brothers s2000's figures was taken on Chris's rolling road at efi parts not on the dastek as it was Chris who mapped it,
Liam was getting just short of 300hp so there's not much difference between the 2 but the rr operater was very impressed with it
Posted 04 September 2012 - 02:07 PM
Posted 04 September 2012 - 02:10 PM
Edited by Nev, 04 September 2012 - 02:14 PM.
Posted 04 September 2012 - 02:14 PM
Posted 04 September 2012 - 02:18 PM
Posted 04 September 2012 - 02:27 PM
21% flywheel losses
I would have expected more like 15%, 27.6' seems like a high temperature to use for correction
Is the 5bhp drop off between run due to the IC heat soaking?
Posted 04 September 2012 - 02:30 PM
21% flywheel losses
I'm no dyno technician but I would guess the second run is due to higher temps? I'm running a pro alloy chargecooler
Edited by Aimy, 04 September 2012 - 02:36 PM.
Posted 04 September 2012 - 02:48 PM
Posted 04 September 2012 - 02:57 PM
Can certainly confirm chris rr is not the place to go to get great pub bhp figures
Good stuff, do you know if the smoothing software was added to that graph? Also reason for spike between 2.5 and 3k?
DG
Posted 04 September 2012 - 03:04 PM
Posted 04 September 2012 - 03:12 PM
Posted 04 September 2012 - 06:03 PM
I'm not sure if it's been smoothed out or not tbh,I don't no with spike between 2.5 and 3k but it's not noticeable on the road
DG
I've got a few little things planned but the main thing through winter is to get some nitrons,yeah I'm really pleased :)I took my car to this rolling road when it was at stage 2, it's good to see the difference from stg 2-4 from the same dynoGood results Aimy, you should be pleased with that! Any more plans?
Liam at Mmg did the mapping for me aswell as all the other bitsIs the mapping done at motorscope Aimy ?
Edited by Aimy, 04 September 2012 - 06:03 PM.
Posted 04 September 2012 - 06:14 PM
Posted 04 September 2012 - 06:17 PM
Sorry my fault i meant did you have the dyno done at motorscope.
Yeah motorscope,have you been there yourself?
Posted 04 September 2012 - 06:21 PM
Posted 04 September 2012 - 06:24 PM
You are on form SlindyDastek dyno..... Might aswell use the deflection of your tits as a better gauge of power.
Posted 04 September 2012 - 06:26 PM
As you will no all rolling roads very even if you knock 20hp of it im still happy with the result :)I've got my difference from stage 2-4 using the same rolling road so I'm pretty happy
