Saab Head
4 replies to this topic
#1 scottslb
scottslb
  • 142 posts
Posted 10 September 2012 - 04:25 PM
ive reposted this as it seem i did it in gallary. i need i new head and im thinking about fitting a b207 head. i just woundered what i would have to do to get it to fit and would i be able to keep my stage three cams dual spring and solid lifters.
#2 vocky
Posted 10 September 2012 - 05:40 PM
One very important thing to remember with the Saab B207 head is never use z22se spark plugs :mellow: The heads are an almost direct swap, the inlet and exhaust bolt pattern is identical and the z22se valves, springs, head bolts and head gasket can all be used, the inlet cam is also a straight swap. However the exhaust cam is shorter on the z22se, so you must blank off the oilway and fit a suitable blanking plate over the extra auxillary drive on the Saab head. You also lose the egr system, not a problem with your webcon throttle bodies. You will also have to use the Saab cam cover unless you modify the exhaust auxillary takeoff so that the z22se cam cover fits.
Edited by vocky, 10 September 2012 - 05:42 PM.
#3 scottslb
scottslb
  • 142 posts
Posted 10 September 2012 - 06:44 PM
for a blank off plate do u mean one like the one we have already fitted to the head now. also what do i have to do with the coil s ive read i would have to change that two. just have to find one now. will any b207 head done.
#4 vocky
Posted 10 September 2012 - 06:55 PM
you need to make one for the exhaust as GM never made one, the inlet cam still uses the z22se blanking plate. Any B207 head can be fitted to the z22se engine and the coil pack / spark plug extensions just need the internal spring stretching 5mm.
#5 scottslb
scottslb
  • 142 posts
Posted 10 September 2012 - 07:09 PM
could u send me some pic s of the cover u made please. it seem a bit to easy.
