Posted 13 October 2012 - 12:07 PM
Posted 13 October 2012 - 12:15 PM
Posted 13 October 2012 - 12:33 PM
Posted 13 October 2012 - 12:40 PM
Posted 13 October 2012 - 02:10 PM
Twist knob and get someone to move the lever.
Do both things at SAME time not separately.
Posted 13 October 2012 - 02:28 PM
Posted 13 October 2012 - 04:45 PM
Edited by Zuber, 13 October 2012 - 04:45 PM.
Posted 13 October 2012 - 04:51 PM
Posted 13 October 2012 - 07:48 PM
Posted 13 October 2012 - 09:28 PM
Posted 13 October 2012 - 09:29 PM
Edited by techieboy, 13 October 2012 - 09:41 PM.
Posted 14 October 2012 - 09:19 AM
Posted 14 October 2012 - 09:27 AM
Posted 21 October 2012 - 01:49 PM
Posted 21 October 2012 - 01:55 PM
jusj pop off the clamp that hold the cable outer case that should give a bit more movementJust had another stab at fixing this but can't figure out how to disconnect the wire without removing the whole box or just cutting it. There's no room to get in underneath it. Maybe next weekend I'll take the whole box out and get it sorted once and for all
Posted 21 October 2012 - 02:07 PM
Hi Guys
Have a stiff ... knob
Posted 21 October 2012 - 02:13 PM
was going to suggest working it in and out with plenty of lubricant but thought better of it 😀
Hi Guys
I can't be the only one who smirked at this.
Posted 27 May 2019 - 05:26 PM
A previous owner will have tried to turn the heater knob on the dashboard too far and the mechanism inside the dash will have bent, preventing it moving properly through it's full arc of adjustment. You'll need to remove the dash cover and straighten out the lever arm and make sure the interior end of the Bowden cable is properly clamped to properly fix it.
In the short term, just move the lever to "hot" at the heater box end and leave it there. If it won't move far enough, disconnect the cable from the top of the heater box and that should allow you to move it as far as it will go.
ETA: Position of the flap control on the heater box is as follows:
Full Cold/Ambient
Full Hot (well maximum warm)
Full blast from the past but my Vx now has heat again! flipped the lever manually. Given the lukewarm air I get, and the fact that the fan is working perfectly Im happy to leave the lever where it is permanently.
cheers forum!
