Oil Catch Tank For Tubby Cam Breather
Posted 16 October 2012 - 09:39 PM
Posted 16 October 2012 - 09:45 PM
Posted 17 October 2012 - 04:06 AM
Edited by Nev, 17 October 2012 - 04:11 AM.
Posted 17 October 2012 - 06:14 AM
Posted 17 October 2012 - 06:29 AM
Posted 17 October 2012 - 06:45 AM
George it will not be gearbox, they never leak with a ahort section of pipe on let alone all the way to a catch tank ;-) condensation I suspect jf no sign of naufhty mayo on header or under oil cap :-)
DG
Cheers
Posted 17 October 2012 - 08:30 AM
Thats interesting as i get an orange/brown water and oily sludge in my catch tank. I get about half a mugs worth every two trackdays but my catchtank for the breather is also shared with my gearbox breather so i cant be sure Whats what.
Perfectly normal sounding to me George, nothing to worry about.
Posted 17 October 2012 - 09:40 AM
I reckon both your gearbox and engine are fcuked, time to get new ones plus a Garret of some description.
And a stand alone ECU. HTH
My breather pipe exits through a hole in the undertray, originally it vented into a catch tank but there was so little collected it wasn't worth it tbh.
If you do route the pipe to exit into the atmosphere be sure to keep it away from hot exhausts...
Posted 17 October 2012 - 09:49 AM
Posted 17 October 2012 - 10:21 AM
Posted 17 October 2012 - 10:30 AM
Posted 17 October 2012 - 10:39 AM
One more question: there are two entries on a catch tank, so one connected to cam cover via a hose.
I guess the other one is to vent the tank, so where do you put the exit of this? Undertray, wheel arch liner, or elsewhere?
The second exit usually has some gauze filter on it to stop dust going into the tank and possibly being sucked into the engine.
Posted 17 October 2012 - 10:53 AM
Posted 17 October 2012 - 11:02 AM
are you keeping the PCV hardpipe from the crankcase, or have you made mods to the camcover baffle / throttle body oneway valve?
Sorry, are you asking me or the OP Steve ?
Posted 17 October 2012 - 08:12 PM
Posted 23 February 2013 - 11:52 PM
Posted 24 February 2013 - 07:38 AM
Defiantly go this route
My catch tank has never needed emptying or even shown signs that it's filling, but why would you want to vent hot crankcase air back into the intake that your trying to keep as cool as possible?
Update.
When I had the cam cover venting to both a catch tank & still with the smaller vent into inlet manifold the catch tank never showed any signs of filling or ever needed emptying, when did the Garrett conversion I capped off both the cam cover vent to inlet manifold and inet manifold & now just vent straight to catch tank, which fills up exactly as George says above!
Can only guess that as the inlet manifold was providing a vacuum it was just all being sucked straight into there before! Gone from never filling to being on wing nuts now to make it easier to empty!
Edited by MrSimba, 24 February 2013 - 07:38 AM.
Posted 24 February 2013 - 05:23 PM
No mate changed the car instead ! I thort that was the cheaper way to go , haha !Did you find a decent cheap catch tank westie?
Posted 24 February 2013 - 07:42 PM
Posted 07 February 2017 - 07:27 PM
