Help Please - Serious Idle Issue
Engine Idle problems help advice ignition coils spark plugs
17 replies to this topic
#1 KevinB
KevinB
  • 51 posts
Posted 24 October 2012 - 11:41 PM
Friends, I love my VX220 and I dare say something is wrong with the engine. In brief - 1) When the engine ticks over it pulsates between 800-1000 revs (it is rhythmic, constant and never changes). The needle (and of course the engine) moves between 800-1000 revs like clockwork. 2) Worryingly this is also occurring when I am driving. Whenever I hold a constant speed the engine pulsates like a heartbeat, dropping 200 revs and then correcting. It never stops. 3) It cold starts fine but once the engine is warm then I have serious trouble starting the car. 4) The problem disappears when accelerating only. I have had advice that it is the ignition coils, car at 40k, not sure if they have ever been changed. Please advise, Kev.
#2 Sammyturbo
Sammyturbo
  • 605 posts
  • Interests:Cars videos photography
Posted 24 October 2012 - 11:46 PM
Air mass meter maybe ?
#3 techieboy
Posted 25 October 2012 - 12:01 AM
NA or Turbo?
#4 KevinB
KevinB
  • 51 posts
Posted 25 October 2012 - 12:25 AM
Just the 2.2 no turbo
#5 Ormes
Ormes
  • 4,612 posts
Posted 25 October 2012 - 05:05 AM
EGR?
#6 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 25 October 2012 - 07:31 AM
throttle body not opening and closing properly?
#7 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 25 October 2012 - 08:20 AM
Where are you based if you put it on your profile it helps as someone near maybe able to help
#8 SteveA
SteveA
  • 9,157 posts
Posted 25 October 2012 - 08:27 AM
Possibly pre cat lambda dead. Any EML codes?
#9 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 25 October 2012 - 08:47 AM
Starts fine cold but not hot? Sounds like compression issues possibly, perhaps on one or two cylinders. Check in the oil filler cap for "mayonaise" and go get a compression test. "Roaming" can be caused by all sorts of sensors working incorrectly/not at all. Where are you based?
#10 techieboy
Posted 25 October 2012 - 08:58 AM
As it's warm running related, start with disabling the EGR valve. That's a pretty much free fix.
#11 Exmantaa
  • 3,982 posts
Posted 25 October 2012 - 09:19 AM
EGR valve and maybe your throttlebody sticks a bit and needs cleaning.
#12 fluffyskg
fluffyskg
  • 428 posts
Posted 25 October 2012 - 09:57 AM
I certainly don't have the same problem but do find that the car is more reluctant to start when warm (it has always started, but it takes noticeably longer for the engine to catch) than when it is cold. Mine idles at around 750rpm which I take to be normal!
#13 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 25 October 2012 - 10:05 AM
Mine is the same at all temperatures except when it has been started from cold and then stopped within a couple of minutes and then tried to start again. Stopud choke flooding the engine :beat:
#14 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 25 October 2012 - 10:13 AM
Does the 2.2 have a cam sensor? Had this sensation on a 2.0 TDI Vauxhall engine before.
#15 vocky
vocky
    Moderator
  • 11,969 posts
Posted 25 October 2012 - 10:14 AM
warm starting could be the engine temperature sensor, fit a new one they are only £20 or so, or it could be the upper lambda sensor
#16 KevinB
KevinB
  • 51 posts
Posted 25 October 2012 - 01:32 PM
I'm based in Derby, and I really appreciate the support guys. I'm not even sure where to start, at the mo.
#17 KevinB
KevinB
  • 51 posts
Posted 25 October 2012 - 01:33 PM
How do I do this?
#18 vocky
vocky
    Moderator
  • 11,969 posts
Posted 25 October 2012 - 01:34 PM
fit a blanking plate, about £7 at the dealers
Also tagged with one or more of these keywords: Engine, Idle, problems, help, advice, ignition coils, spark plugs
