Replacing The Steering Wheel Universal Joint - How Please?
Posted 12 November 2012 - 05:37 PM
Posted 12 November 2012 - 07:21 PM
Posted 12 November 2012 - 09:08 PM
Posted 13 November 2012 - 06:52 AM
Posted 13 November 2012 - 07:27 AM
Posted 13 November 2012 - 08:17 AM
Posted 13 November 2012 - 08:30 AM
Posted 07 June 2014 - 11:13 PM
Posted 08 June 2014 - 06:58 AM
Posted 08 June 2014 - 07:16 AM
Posted 08 June 2014 - 08:07 AM
I bought a new steering UJs but just couldn't figure out how to get the top one off.
Just a note to say that the shaft that the top UJ attaches to has a slot in it, not a groove, so not only do you have to remove the bolt entirely to get the UJ off but you also have to align the UJ to the slot to get it back on.
I would also recommend slackening off the rack mounting bolts to give enough play to get the rod on when refitting: Put the top joint on and insert the bolt to stop the UJ falling off but don't tighten the nut so the joint can slide along the slot which is quite long so allows a reasonable amount of movement. Slacken the rack mounting bolts so that you can slide the top UJ up and there is enough movement to fit the bottom joint. Check the rack is centred to the steering wheel. Tighten the rack bolts. Fit the bottom UJ clamp bolt and nut and tighten. Tighten the upper UJ clamp nut. Extract yourself from the foot well!
Whilst not exactly fun, it's not the worst job I've done on the car.
Posted 08 June 2014 - 09:00 AM
Posted 08 June 2014 - 09:44 AM
LOL. Having a harness bar there to grab hold of certainly helps to heave yourself out!
