Wishbones - Symetrical?
16 replies to this topic
#1 JamesC
JamesC
  • 991 posts
  • Interests:Cars, Beer, Diving, not necessarily in that order....
Posted 15 November 2012 - 09:26 PM
Following some advice I requested earlier I now have the upper front wishbones of the car. However, It would apepar I have a bit of a problem. I am under the assumption that both side are supposed to be symetrical? Below is a picture of the removed wishbones:
The wishbone on the right appears to be bent. Am I correct in thinking it should be parallel to the one on the left? I guess if it is bent I need to get the bottom one off an assess whether that needs replacing as well, any second hand parts available?
#2 JG
JG
  • 13,617 posts
Posted 15 November 2012 - 09:30 PM
yep, thats knackered. There are indeed symetrical. The only ones are interchangeable though (by fliping them) are the top rear wishbones. Thats had quite a shock. I've never seen a bent front shock. Unlike the rear, there is nothing for the front to hit, so i guess thats had an accident.
#3 JG
JG
  • 13,617 posts
Posted 15 November 2012 - 09:34 PM
Elise parts do a good range of replacements, which come bushed and ball jointed.
#4 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Fuggered old son. Needs a newie.
#5 JamesC
JamesC
  • 991 posts
Posted 15 November 2012 - 09:38 PM
To be honest I have a feeling it as as well, there doesnt appear to be any creasing damage to the wishbone mounting locations, but the headlight on the drivers side does have a date sticker that makes it newer than the car. Everyhthing seems straight besides the wishbone. When I last had the GEO set only this corner required any real adjustment. Just hope I dont unearth anything else too serious.....
#6 JamesC
JamesC
  • 991 posts
Posted 15 November 2012 - 09:39 PM
Just had a look on there, seems a new one might be the way to go, unless a cheap second hand one comes up, I have new bushes ready to fit and these are all going for blasting and coating anyway.
#7 Bumblebee
Bumblebee
  • 7,592 posts
Posted 15 November 2012 - 09:41 PM
Do all the headlights have a date on them?
#8 Mike (Cliffie)
Mike (Cliffie)
    Back in a VX
  • 13,354 posts
Posted 15 November 2012 - 09:49 PM
Originally, yes but it is only a paper sticker; mine have long fallen off.
#9 vocky
Posted 15 November 2012 - 09:58 PM
just buy genuine lotus Europa wishbones, quite reasonable prices compared to vauxhall
http://www.deroure.c...&SMO=0&ST=&SC=0
upper = £138 +vat, you might be able to get a discount if you go to a friendly lotus dealer
http://www.deroure.c...SC=0&PBID=48617
http://www.deroure.c...SC=0&PBID=48618
Edited by vocky, 15 November 2012 - 10:00 PM.
#10 CocoPops
CocoPops
  • 17,182 posts
Most parts are dated. Plastics/fibreglass often have date grids to show manufactured date.
#11 JG
JG
  • 13,617 posts
Posted 15 November 2012 - 10:17 PM
My brand new headlights delivered August and September 2012 are dated 2009 and 2010 :lol:
#12 techieboy
Posted 16 November 2012 - 12:54 AM
Surprised you didn't reject them and ask for a matching pair.
#13 JG
JG
  • 13,617 posts
Posted 16 November 2012 - 07:28 AM
I'd have probably got one from 2008 :lol: Anyway, the second came in a roundabout sort of a way and beggars can't be choosers, and they are identical
#14 Nev
Posted 16 November 2012 - 10:55 AM
The wishbones are designed to be sacrificial on impact and are made from thin guage metal for this (and other reasons). You will find they can bend a lot before the hard points get damaged, so with such minimal looking damage I would be most surprised if you had any mounting point damage. :)
Edited by Nev, 16 November 2012 - 11:09 AM.
#15 JamesC
JamesC
  • 991 posts
Posted 16 November 2012 - 01:06 PM
Am I right to assume N/A are the same as Turbo wishbones?
#16 siztenboots
Posted 16 November 2012 - 01:12 PM
different but even from the factory you get odd unmatched pairs , ie. NA with one turbo lower wishbone , depends what they had in stock try junks as he had some brand new upper rear wishbones with balljoints and bushing all done for very good price
#17 JG
JG
  • 13,617 posts
Posted 16 November 2012 - 01:23 PM
Fronts are
Rears tops are
Rear lower wishbones are slightly different. Though early turbos has the same as the NA. they are all interchangeable between NA and Turbo
