Project has started long time ago but now we're making big steps and the expectations of the car to be 'drivable on road and track' are high for second quarter of 2013.
Let me start with the wanahave specs:
Lotus GT3, 99-PR-XZ (road legal)
Engine: 530-625bhp at 8500rpm, weight: 825-855kg
Exterior and chassis
- Lotus Carbon Fibre Exige GT3 wide-body, shortened wheelbase
- Opel Speedster 2.0T chassis, sub-frame and engine
- Composite front-splitter, CF reversed wing, aluminium diffuser
- CF bottom panel parts, CF mirrors
- Lightweight interior panels, aluminium bulkhead
- Full roll cage
Air/fuel intake
- Upgraded air filter housing and fresh air intake, high-flow intake manifold, 62mm throttle-body
- Borg Warner EFR7064 twin scroll turbo
- Pro-alloy Charge cooler (strengthened for 2.5bar)
- Adjustable Water/Methanol injection
- 850ccm fuel injectors
- New engine (rebuild 2012): engine block, turbo, pistons, camshafts and others, steel crankshaft
- High performance push rods, crankshaft support plate, piston bottom cooling
- Lightweight flywheel, balance shafts removed
- Dry sump system (tank in front)
- Aggressive camshafts, solid valve lifters, flowed cylinder head, bigger valves, dual valve-springs
Twin scroll exhaust manifold (heat wrapped)
- Modified exhaust 76mm Ti, pre-cat removed
- Damper and cat combined
- Paddle clutch, limited Slip Differential (Quaiffe), 5-speed manual gearbox
- Engine mounts strengthened
- Dry sump tank in front (battery location). No oil cooler (oil tank and pipes/chassis will cool the oil)
- No electrical water pump
- Lightweight 70-90A Alternator (2.58kg) and bracket
- Öhlins 2-way adjustable race version, Adjustable anti roll-bar, Polyurethane busses
- Road usage (Centre lock) wheels: Dymag Magnesium and Yokohama 048’s
- Slicks: Lotus sport magnesium 7Jx16 + Dunlop 200 580 R16 (12.3kg) 8Jx17 + Dunlop 235 610 R17 (15.6kg)
- GT3 spec brakes + proportional limited bias valve, Steel braided brake lines
- Aluminium (Nitron) Uprights with internal airflow
- Wishbones in 4130 steel
- 52 litre fuel tank, upgraded fuel pump
- CF seats, lowered (1-2cm) on L-shaped aluminium mounts
- 4-Point Harnesses
- OMP Carbon fibre steering wheel, airbag removed
- Dash rev-counter extended range, up to 8.500 rpm
- Racelogic traction control with digital adjuster, ABS signal filter
to improve input signal under 20MPH
- Lambda sensor monitor
- Stinger DSI, including laser shield front protection
- Racelogic Video VBOX 2 cameras and USB logging
- MIM01 Input module, to include in logging:
- GPS data (e.g. speed and position) and track logging
- RPM1: Engine RPM
- A1: Turbo RPM
- A2: Boost pressure
- A3: Traction control indicator( to visualize engine cut-offs/wheel-spin, pin 4 on the B connector – it sits at 5v but goes to GND when cuts are made.)
- A4: LMM Air mass meter value
- A5: Oil pressure
- A6: Lambda sensor
- A7: Water/Methanol injection status
- A8: Brake signal
- K1: Oil temperature
- K2: Air intake temperature
- Roof vent system (interior heating system removed)
- Improved tow-hook, Rear license plate on aluminium strips
- Integrated Fire extinguisher 2.25kg Remote Pressure Discharge Weight 3.09kg
- Cruise control
- 2nd fan connected to fog light switch
- Front and rear clams with a single-plug (12/24 pin AMP) wiring disconnect
- Battery behind co-driver seat(?) Li-Ion 1,75kg, cut-off switch, located near front right-side door
- Lexan side windows (-6kg)
- Toe link upgrade (-1.2 kg)
- Long drive shaft, increased track width (might no longer fit on trailer?)
- Adjustable rear wing (http://aeromotions.com/news/ )
- Wider track (wishbones and drive shafts, http://www.driveshaft.co.uk/ )
