Z20Leh Piston Rings
9 replies to this topic
#1 siztenboots
Posted 07 December 2012 - 09:45 AM
Looking for some advise on replacing a set of piston rings on some Astra VXR pistons to then go into a Z20let block. I have had a good price back from Kieron at autovaux , but no specific details about the ring sizes as I believe there is three sizes 85.990 86.000 86.010 Part number I've struggled a bit , but 55556803 is PISTON, PIN AND RINGS, ASSY., CYLINDER BORE 86.010 MM I need to be sure as there are height differences between z20leh and z20let , I've documented this somewhere but search isn't working
#2 Nev
Posted 07 December 2012 - 10:24 AM
I don't have any idea personally Steve. I'd recommend rining Klassen up in Germany and offer him £25 for some advice.
#3 siztenboots
Posted 07 December 2012 - 10:28 AM
ah found it , its the c20let piston rings that differ to the z20lex , information provided by Mahle Z20LET - Ring sizes are the same as the Z20LEH, 1.2mm, 1.5mm, 2.5mm
#4 vocky
Posted 07 December 2012 - 12:50 PM
get the 86.01 size and adjust the ring gaps yourself :sleep:
#5 siztenboots
Posted 07 December 2012 - 12:54 PM
file them to suit then?
#6 vocky
Posted 07 December 2012 - 01:06 PM
you will need to grind them with a dremel, make sure the end stays perfectly square.
#7 siztenboots
Posted 07 December 2012 - 01:13 PM
okay thanks, quick bit of 86.010 * PI , means a difference in ring circumference of 0.03mm if my sums right
#8 siztenboots
Posted 07 December 2012 - 01:25 PM
this should be a good guide for me http://www.wiseco.co.../RingEndGap.pdf
#9 Nev
Posted 07 December 2012 - 05:15 PM
God, how can a human possible be that accurate by hand ?! Good luck !
#10 vocky
Posted 07 December 2012 - 05:48 PM
just follow the instructions on that wiseco link, dead easy to do with some feeler gauges Once you have put one piston ring into the bore use an upsidedown piston to push it further into the bore (which will straighten it up), then measure the gap and adjust if required
