Anti-Rattle Door Pins Query
13 replies to this topic
#1 Kal
Kal
  • 285 posts
Posted 13 December 2012 - 08:42 AM
Hi all,
Brief question; in the quest for less rattles:
http://www.elisepart...r-striker-pins/
Will these fit the VX? They mention the original ones in lotus being GM ones, so guessing so; but prefer to know before I buy :D
Also; does anyone have a picture of original doorpins? Unsure if mine are new or not, but 'think' thats where the rattle is coming from.
Many thanks all.
#2 fezzasus
Posted 13 December 2012 - 08:57 AM
Yes they will fit. A quick test to see if your door pins are rattling is to wrap them in tape. Then do what I did and leave the tape on because it's much less effort than changing the pins.
#3 T VXT
T VXT
  • 433 posts
A few layers of insulation tape around your current door pin (it make it approx 1mm wider) will work too.
Add the tape slowly and keep trying the door until you get a more satisfying chunk when shut :happy:
You can see if that stops the rattle thumbsup
......too slow
Edited by T VXT, 13 December 2012 - 08:57 AM.
#4 Kal
Kal
  • 285 posts
Posted 13 December 2012 - 08:58 AM
Thats why I love this place and you guys; Will give it a try :)
#5 T VXT
T VXT
  • 433 posts
Posted 13 December 2012 - 08:59 AM
thumbsup
#6 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 13 December 2012 - 09:21 AM
Noticed a big change once I fitted these........... Now, just the other 100 other odd sounds to fix...
#7 fezzasus
Posted 13 December 2012 - 09:25 AM
Best thing i've done to mine to stop rattles is stick 1.5mm thick adhesive foam behind all the trim: http://www.ebay.co.u...=item3f07661712
#8 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 13 December 2012 - 11:29 AM
Works a treat the tape. Needs replacing once in a while but certainly works a treat.
#9 SPLAM
SPLAM
  • 6,491 posts
Posted 13 December 2012 - 12:54 PM
If they look skanky, they are oem. If they look shiny, they have been replaced.
#10 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 13 December 2012 - 03:47 PM
+1 for insulating tape. Tape has the bonus that you can alternate the colour of your door pins as you see fit :lol:
#11 Ormes
Ormes
  • 4,612 posts
Posted 13 December 2012 - 07:55 PM
If you change the pins... BE CAREFUL as there are around 4 washers worth about £50 between the GRP and the captive nut on the rollbar.
#12 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 13 December 2012 - 09:30 PM
I suspect though the rattle isn't actually the door mechanism, but will be the window mech.
#13 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 14 December 2012 - 07:03 AM
Most probably. Door pins worked in mine though.
#14 iVXT
iVXT
  • 680 posts
Posted 14 December 2012 - 03:23 PM
Would this stuff be ideal for stopping the rear speaker panel rattling? I was thinking of double sided velcro but this is a lot cheaper.
Cheers.
