Best Spark Plugs For Na
With Uprated Cams
13 replies to this topic
#1 Paulus H
Paulus H
  • 2,063 posts
Posted 14 December 2012 - 11:08 AM
Since fitting the uprated cams the car sometimes stutters when pulling away after it has been idling for a while such as at traffic lights. Is there a different spark plug type that is less susceptible to this? Kind regards, Paul
#2 vocky
Posted 14 December 2012 - 11:31 AM
best plugs are OEM triple electrode :sleep:
#3 Paulus H
Paulus H
  • 2,063 posts
Posted 14 December 2012 - 12:17 PM
Many thanks!
#4 oakmere
oakmere
  • 2,143 posts
Posted 14 December 2012 - 01:09 PM
As Vocky says the originals are good. As an alternative Denso ITV20 are good.
Edited by oakmere, 14 December 2012 - 01:09 PM.
#5 Ivansp
Ivansp
  • 6 posts
Posted 25 June 2015 - 10:41 AM
Hi Paul, i've a similar problem..
So, at last, what type of spark plugs have you used?
I would like to try the NGK Laser Platinum Spark Plug from Courtenay..
Manu thanks for the reply
Ivan
#6 Paulus H
Paulus H
  • 2,063 posts
Posted 27 June 2015 - 11:22 AM
Hi, Well done with the search for this topic!! I am afraid I stook with OEM. If you find any way to get a better idle please let me know. All the best, Paul
#7 oakmere
oakmere
  • 2,143 posts
Posted 27 June 2015 - 09:36 PM
The poor idle is nothing to do with the plugs but the closed loop algorithm in the ecu. With the schrick cams I had perfect idle when locked in open loop for idle. This can be seen with the std ecu when you start from cold idle is ok then as the car warms up and closed loop activates the idle becomes lumpy. The wilder the cams the worse idle will be.
#8 Paulus H
Paulus H
  • 2,063 posts
Posted 28 June 2015 - 12:21 AM
Interesting, please advise the bsst soulution. Kindly, Paul
#9 oakmere
oakmere
  • 2,143 posts
Posted 28 June 2015 - 07:37 PM
Paul Which cams are you using?
#10 Paulus H
Paulus H
  • 2,063 posts
Posted 29 June 2015 - 12:31 AM
Hi, they are actually Piper. I have no real history of the timing as I bought them from a guy on the Z22SE site.... Paul
#11 oakmere
oakmere
  • 2,143 posts
Posted 29 June 2015 - 11:08 AM
Paul the only way you will improve idle is with stand alone ecu or with the Dutch software where you can adjust the idle map. When the Dutch version 3 comes out it will have more adjustment within the idle map. If you just want a remap CS can increase the idle speed which will help you.
#12 Paulus H
Paulus H
  • 2,063 posts
Posted 29 June 2015 - 04:32 PM
Many thanks for that. I may see if Liam can raise the idle a little as he is based around 15 miles from me. For me, driving to Cromer is a pain in the ass.
Thanks again, Paul
#13 myles
myles
    Sausagefest
  • 2,084 posts
Posted 29 June 2015 - 04:49 PM
I have Piper regrinds and have a bit of a lumpy idle (oo err); unless it is too crazy I wouldn't be too concerned.
Saying that though, when I come back to the UK I'll be going down the Dutch Software road, but not necessarily for the idle correction.
#14 oakmere
oakmere
  • 2,143 posts
Posted 29 June 2015 - 08:56 PM
All Dutch equipped cars with cams have the idle set at 900rpm.
