Fitting Turbo Ears / Vents To An Na
turbo ears side vents dumbo
10 replies to this topic
#1 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 15 December 2012 - 12:00 PM
Guide to retro-fitting tubby vents courtesy of s20vxl,
He's made a great job of it, and doesn't look quite as complex as first imagined:-
"here is how to do it
1. Jack up the car and remove rear wheels
2. Remove the wheel arch liners.
3. Drill out the plastic rivets on the old grills and pull them off. They are stuck with double sided tape so take a bit of pulling.
4. Offer up the turbo vent up and see how it fits. The flat panel behind the door is just bonded in place and if you look round the edges you can see it comes away.
5. Working from inside the wheelarch jam a pry bar down the back of the cover levering it off but be carfull not to puncture the clam. Keep
doing this till the larger section can be taken off.
6. Now offer the vent up again and see how much has to be taken off the back of the clam section to
allow the vent to sit nicely. I trimmed it away using and air saw but a coping saw could be used. NOTE: Make sure you only take away a small amount at a time offering the vent up all the time till it fits nicely.
7. Once done sand away any bonder left where you pulled the blanking plate off and spray it black as you will see it through the vent.
8. Fit the vent in place and drill two holes for plastic push rivets to go through (one in the door shut and one at the top of the vent inside the grill).
9. Tape the back of the vent tight to the clam so there is no gap and bond it in with a strong bonder like windscreen bonder, they are bolted in at the back edge on the turbo but the studs are not present on the n/a.
You won't need to do any paintwork if you are careful, other than the vents themselves.
Hope it all makes sense and good luck."
And the pics...
#2 CocoPops
CocoPops
  • 17,182 posts
Posted 15 December 2012 - 12:08 PM
My tips... Remove as much of the "gunk" and crap left after removing the "trim" (white fibreglass and glue) in pic 2, but leave the raised island part. Also, don't tiger seal them in, but use big head fastner bonded to the sill, allows you to remove and refit ears easily.. http://www.ecfibregl...eel-thread.aspx
#3 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 15 December 2012 - 12:28 PM
Can you post your photos of the fasteners bonded in please Lee. thumbsup
#4 Nelly Vx
Nelly Vx
    3/3 Of a Queen
  • 5,928 posts
Posted 15 December 2012 - 12:43 PM
These fasteners are the same ones I used and I used 6mm wing nuts and 6mm repair washers to secure them :-)
#5 CocoPops
CocoPops
  • 17,182 posts
Posted 15 December 2012 - 01:01 PM
No pics of fasteners fitted thumbsdown http://www.vx220.org...40#entry1288122 Has some general ear fitting pics. You can see what I mean about the "island" I used some matt black paint to tidy the area up.
#6 J4EY D
J4EY D
  • 3,236 posts
Posted 15 July 2013 - 01:03 PM
Any tips for getting that fibreglass panel off? It won't bloody budge!!
#7 J4EY D
J4EY D
  • 3,236 posts
Posted 15 July 2013 - 01:14 PM
Never mind, just had to find some balls :lol: Came off in about 5 pieces :)
#8 J4EY D
J4EY D
  • 3,236 posts
Posted 15 July 2013 - 01:15 PM
Double post
Edited by J4EY D, 15 July 2013 - 01:16 PM.
#9 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 15 July 2013 - 01:21 PM
A bit of brute force and hoping that the cracking sound you hear is the bit in your hand breaking away rather than the breaking the bit on the car!
#10 rik
rik
  • 2,187 posts
Posted 15 July 2013 - 03:33 PM
i did/doing this too, I found a useful tool, it's like a carpenter's chisel (not sure on the real name) for removing the goo without damaging the sill (too) much
Also I has to repaint that bit where the goo is because you can see that mess it if you use the knock-off ears from the guy on here - the ones with the mesh rather than the inserts
#11 Zuber
Zuber
  • 1,429 posts
  • Interests:Finding a way to motivate myself to get fit. Anything Interesting.
Posted 21 August 2013 - 07:56 PM
Just reading this thread for obvious reasons. At first glance when I saw this photo, I thought it was a VX220 Estate :)
Edited by Zuber, 21 August 2013 - 07:57 PM.
