Traction - Lack Thereof!
traction TC slippery cold damp
57 replies to this topic
#1 Dunk
Dunk
  • 1,224 posts
  • Interests:WLTM reliable, quiet, tidy one for LTR.
Posted 27 December 2012 - 09:35 PM
Good ladies and gentlemen Just back from a quick, evening spin (almost literally) I was surprised to how little traction I'm getting from the rear. Not sure if it's completely normal for a regular tyre or if mine are old and the compound a bit aged but when boost comes on strong in my Stage 2 (247bhp-ish) in 3rd gear, on a straight bit of motorway tarmac, I get wheelspin! I'm still running it on the Yoko Advan Neova AD08s that it came with. I don't know exactly what the RPM/MPH was at the time as I was VERY focussed on keeping it together and heading in the right direction. Opinions? Is it normal for these tyres? Might it just be time to get replacements more suitable for these temps? Cheers D
#2 MrSimba
MrSimba
  • 5,197 posts
Posted 27 December 2012 - 09:39 PM
December in the cold & damp with about 260ft lb... Normal! Even more so if you've an aggressive geo (and heavy right foot!)
Edited by MrSimba, 27 December 2012 - 09:42 PM.
#3 G-Bob
G-Bob
    Embarrassing VX's in an MX5
  • 8,256 posts
Posted 27 December 2012 - 09:42 PM
Yup.... Also, its pretty cold tonight duncs. What are your tyre pressures like? Are they over inflated?
#4 Sammy
Sammy
  • 1,206 posts
Posted 27 December 2012 - 09:47 PM
My backend stepped out when changing lanes the other week, 4th gear accelerating gently from 45 (50 limit dual carriageway). Just drive carefully. AD08's in a standard NA.
#5 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 27 December 2012 - 09:49 PM
Road surface temps will have been about 4C in most of the UK this aft (I suspect) and thought the Yokos were more of a summer tyre. Plus that is enough torque to break traction.
#6 Dunk
Dunk
  • 1,224 posts
Posted 27 December 2012 - 09:51 PM
Hmmm. Haven't checked the pressures :blush:
I'm pretty light on my loafers gentle on the pedals but I did fancy burying the pedal and keeping it there to see what happened. Squirming is what happened. Never had that in third, over 3k. Hello Stage 2. Interesting.
:D
#7 Dunk
Dunk
  • 1,224 posts
Posted 27 December 2012 - 10:06 PM
Yikes! I'll be treating the right pedal like an eggshell.
Yup - seems so. With a bit of luck I'll still make it to Leeds in one piece!
:D
#8 Andy_VX
Andy_VX
  • 2,050 posts
  • Interests:Cars, Boats, F1, Cycling, Home Cinema, Music.
Posted 27 December 2012 - 10:19 PM
:yeahthat: I'm very light on the loud pedal through 1st, 2nd and 3rd in this weather! Like you i had a "moment" when it was cold and have been a lot more careful since! :rolleyes:
#9 nicollow
nicollow
  • 3,801 posts
Posted 27 December 2012 - 10:21 PM
I'll take it out and see if its all doing as it should, if you want fella ;)
#10 Paulus H
Paulus H
  • 2,063 posts
Posted 27 December 2012 - 10:55 PM
Are you over inflated? I have to say my AD08's have really good side bite, but do not have the forward traction of the near bald T1R's that they replaced. Are your dampers set too hard? Kind regards, Paul
#11 VXR
VXR
  • 986 posts
Posted 28 December 2012 - 08:11 AM
I know that feeling,my aggressive rear camber makes mine impossible to drive on a damp road!nearly went through a wall up in the Peak District last month!! A trip to MMG is on the cards in the very near future!!
Edited by VXR, 28 December 2012 - 08:12 AM.
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,288 posts
Posted 28 December 2012 - 08:38 AM
Possibly a diesel patch ;)
#13 Dunk
Dunk
  • 1,224 posts
Posted 28 December 2012 - 08:50 AM
Possibly but I've had some squirming under part throttle once the boost comes on. It can be a bit 'all or nothing' Makes me consider DG's Standalone upgrade...
#14 slindborg
Posted 28 December 2012 - 08:56 AM
You'll still have traction problems if the camber/tyre condition/weather conditions/everything else that matters isn't favourable despite having spent a fortune on a spangly PCM.
#15 Dunk
Dunk
  • 1,224 posts
Posted 28 December 2012 - 08:58 AM
Ha ha. Yeah, just meant for a more even delivery of the good stuff... Before anyone says it...no, I don't regret buying a Tubby over a NA/SC. :D
#16 G-Bob
G-Bob
  • 8,256 posts
Posted 28 December 2012 - 09:01 AM
How will that help? He wants the car to STOP going sideways! :poke:
#17 Dunk
Dunk
  • 1,224 posts
Posted 28 December 2012 - 09:03 AM
To be clear, I'm happy with sideways but I'd like to have a bit more predictability over when it's going and *some* degree of modulation!
:D
:D
#18 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,220 posts
Posted 28 December 2012 - 09:17 AM
Kames :poke:
#19 jameso
jameso
  • 2,336 posts
Posted 28 December 2012 - 09:22 AM
Very stiff springs seemed to not help me either, when I moved to the CF ARB setup and on 450 rears my rear traction improved massively.... But it's more likely to make a difference on worse surfaces that a flat motorway I reckon?
#20 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 28 December 2012 - 10:11 AM
If those Advans are anything like R888 then their "Safe" operating temperature range is about 8 degrees celcius IIRC. However if the back end is set to stiff then this will reduce grip. That said you don't want it too soft either. Don't want passengers thinking the car is comfortable otherwise they want to come out with you all the time, which reduces acceleration. :poke:
Also tagged with one or more of these keywords: traction, TC, slippery, cold, damp
