Ad08 Vs R888, A048 Road Noise And Grip
18 replies to this topic
#1 AllanM
AllanM
  • 53 posts
Posted 12 January 2013 - 11:08 AM
I am about to get tyres for my new rims (ATS 8x17 & 9x17). I use my car for Trackdays, Nürburgring trips and Sunday drives. I am looking at AD08, R888 and A048. I heard that proper trackday toyes (R888, A048) are very noisy on the road after having been used on track. What are your experiance ? How big are the are the grip differece between AD08 and R888, A048 ? Greetings Allan
#2 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 12 January 2013 - 11:12 AM
Yes a little bit noisier but you'll get used to it.
#3 anz3001
anz3001
  • 1,617 posts
Posted 12 January 2013 - 11:33 AM
I
in those circumstances surely road noise is right at the bottom of the list of considerations
#4 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 January 2013 - 11:47 AM
You get a bit more tyre roar from 888's but as Chris said, it's not unbearable. I've tried 888's and now onto AD08's but it's a little early to report on them. They seem fine. If you can afford them and accept the wear rate and increased risk of aquaplaning then go with 888's.
#5 jameso
jameso
  • 2,336 posts
Posted 12 January 2013 - 04:19 PM
Personally I prefer the slightly stiffer sider wall on the yokos.... I found r888 and r1-r (my current tire) a little spongy. I also find oddly my r1-r not much better than semi slicks in the wet, seems to aquaplane just as much.... Or maybe I forgot how bad semi slicks were as haven't driven on them for about 18 months J
#6 s-express
s-express
  • 311 posts
  • Interests:cars (obviously) but also turning into a bit of a conservationist....which doesn't really make sense...
Posted 12 January 2013 - 08:35 PM
AD08's make a perfect all-weather tyre with decent wet weather grip and water-shedding properties. On track they are predictable and resist wear better that A048's and R888's IMHO.
#7 JG
JG
  • 13,613 posts
Posted 12 January 2013 - 08:38 PM
My A048s are silent compared to my 888s
#8 RobNA
RobNA
    RobSC :)
  • 2,856 posts
Posted 12 January 2013 - 09:31 PM
I have been looking at getting a set of AD08 for when these A539 rears wear out. I wouldn't have started a thread to ask where the best place is to buy a set of AD08 is, but I will ask it here :) I have looked on Camskill to far...
#9 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 12 January 2013 - 09:32 PM
I traded blackcircles off against tyretraders Rob. I was after 205/235's though.
#10 CocoPops
CocoPops
  • 17,182 posts
Posted 12 January 2013 - 09:33 PM
Our local place was 450 fully fitted for a set of ad08s last feb. They rose to 500 fitted in the summer.
#11 JG
JG
  • 13,613 posts
Posted 12 January 2013 - 09:41 PM
Yep, AD08s make a lot of sense on paper and mostly in practice too. Feel in the dry isn't quite as sharp as the 48s, and the front profile looks odd.
#12 Rusty789
Rusty789
    Ginger Ninja
  • 2,120 posts
Posted 13 January 2013 - 10:58 AM
Where was this? I'm going to be needing new tyres when I get the car back!
#13 JG
JG
  • 13,613 posts
Posted 13 January 2013 - 11:01 AM
Tyre Barn Newbury. Brilliant Service and always the cheapest for fitted tyres. He also swaps tyres over and balances for free, if he knows you'll buy his tyres when you come to replacing. The only downside is that he can't get 888s or 48s.
#14 Sammy
Sammy
  • 1,206 posts
I think we can all agree the trade-offs are more than worth it. Full tread depth too!
#15 JG
JG
  • 13,613 posts
Posted 13 January 2013 - 11:17 AM
i swaped back to cut slicks (one set of 48s, one set of 888s) so i didn't think the trade offs were worth it, but i can see why lots of people do.
#16 AllanM
AllanM
  • 53 posts
Posted 13 January 2013 - 12:59 PM
Thanks for all your comments :)
They sound like the good allround choice.
Looking at the pattern it makes sence. It is what i hoped for.
Are you running ATS rims ?
If yes. Why did you go for 205/235 and not 215/245 ? Rubbing ?
Do you have any picture of them on the car ?
My problem with A048 is that the rears 245/40-17 only is available in the MH (Medium-Hard) compound. If i want M (Medium) rears i have to go 235/45-17.
Fronts 215/45-17 are available both M and MH.
What compound are you running ? Would you change compound if they where available ?
Allan
#17 JG
JG
  • 13,613 posts
Posted 13 January 2013 - 01:11 PM
I chose the lotus oem LTS compound. To be honest, if you're even thiking about compounds then the AD isn't going to cut it.
#18 AllanM
AllanM
  • 53 posts
Posted 13 January 2013 - 01:21 PM
I am only thinking compounds because i fear that our lightweight cars will have problems getting heat into the MH compound.
But you might be right or i am just overthinking thinks. :wacko:
#19 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 13 January 2013 - 01:33 PM
Allan. I am running on DTCs and went 205/235 as I didn't want to cut inserts into the sills due to rubbing. I'll see if I have any pics, no up close ones from what I recall.
