Brakes.... Are Yours This Rubbish ?
Posted 28 January 2013 - 08:13 AM
Posted 28 January 2013 - 08:16 AM
Posted 28 January 2013 - 08:38 AM
Posted 28 January 2013 - 09:22 AM
:They're very good, but take some time to get used to when coming from an overly brake assisted car.
You actually have to press the brake pedal in the VX which is the way it should be. The car is more focused and has feel and progressiveness. What car are you comparing it to? Many modern cars designed to be ok to drive by grannies with arthritic ankles will have you diving towards the windscreen if you so much as sneeze on the pedal. This much like a turbo kick gives you a false sense of power. It can seem like you are having to abuse the brakes a bit on the VX to really get the car to pull up swiftly but if everything is in good order this should not really be the case. The brakes should be more than adequate in standard form and pretty damn good with uprated pads etc.
Posted 28 January 2013 - 09:48 AM
Posted 28 January 2013 - 09:50 AM
Do a search on here. You will have cheap pads, change them and all will be cured. Perhaps discs and fluid could do with a change, it isn't expensive, but it's pads that matter.
I bought some new discs and pads - standard OEM discs are fine for normal road/light track use, retail around £15 a corner on eBay so not expensive...and you cant go wrong with mintex 1144 pads, again not majorly expensive
You may want to upgrade to braided lines too as a lot do, and as above change the fluid
Transformed my car for very little money
You may want to upgrade to braided lines too as a lot do, and as above change the fluid (depending on if you track it. every 6-12 months)
Edited by D3YMO, 28 January 2013 - 10:19 AM.
Posted 28 January 2013 - 09:51 AM
Posted 28 January 2013 - 09:54 AM
Posted 28 January 2013 - 11:00 AM
Posted 28 January 2013 - 12:42 PM
Posted 28 January 2013 - 01:51 PM
Posted 28 January 2013 - 01:55 PM
Edited by Bumblebee, 28 January 2013 - 01:57 PM.
Posted 28 January 2013 - 01:59 PM
Posted 28 January 2013 - 02:01 PM
Posted 28 January 2013 - 04:03 PM
Posted 28 January 2013 - 05:18 PM
This. Or if there are any local members to you ask them to have a look (possibly take to an empty at park and have a go of one another's to test the difference). If its as bad as you say then it'll be pretty obvious to someone that's used VX's for a while!With respect, we're talking about something as safety critical as brakes. If you don't know where to start looking then the answer should be 'take it to a specialist' rather than 'do a search'
Apologies if that came across rude, it wasn't intended but sometimes a specialist or experienced eye is the place to go.
Posted 28 January 2013 - 05:56 PM
Posted 28 January 2013 - 06:18 PM
Posted 28 January 2013 - 07:39 PM
