F23 Gearbox Oil Level
14 replies to this topic
#1 MrSimba
MrSimba
  • 5,197 posts
Posted 20 February 2013 - 06:36 PM
Plenty of threads previously about this but always takes me a while to catch up! My 1st / 2nd gear change always was 'notchy' especially when cold even with the gearbox oil just being changed for RedLine MT90, we put 1.9lts in and the OE spec is about 1.75lts Reading on here and other ZLET sites that as long as you have a breather fitted the box works a lot better with 2.2/2.3ltrs in so topped it up yesterday & took the car over to see Liam @ MMG today which is about a 100 mile round trip, the gearbox is noticeably smoother, much much better, and 1st / 2nd just slides in cold or hot :) Amazing how just another 400ml of oil has made such a difference thumbsup
Edited by MrSimba, 20 February 2013 - 06:37 PM.
#2 JamesC
JamesC
  • 991 posts
  • Interests:Cars, Beer, Diving, not necessarily in that order....
Posted 20 February 2013 - 07:09 PM
I need to do mine this weekend but can't find the level check plug? Or did you just put in around 2.2ltrs and leave it to it?
#3 JamesC
JamesC
  • 991 posts
#4 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 20 February 2013 - 07:20 PM
Level plug is on the side facing the rear of the car. You need to have the gearbox breather pipe on to add the extra otherwise your rear left tyre will get a little messy. If your adding extra you won't need to touch the level plug. Filling plug is on the top
#5 JamesC
JamesC
  • 991 posts
Posted 20 February 2013 - 07:23 PM
I've added a breather pipe and found the filler just struggling to spot the level. Will have to have a good look for it, just out of interest. On the basis of MrSimbas advice I think I will go for a slight overfill anyway.
#6 RalphyBMW
RalphyBMW
  • 764 posts
Posted 20 February 2013 - 07:35 PM
I didn't bother checking the level on mine, just drained and refilled with around 2.3 litres. Obviously fitted the breather first.
#7 MrSimba
MrSimba
  • 5,197 posts
Posted 20 February 2013 - 07:46 PM
If you drop the rear tray the level plug is very visible, I just got a syringe and put another 400ml in :)
#8 slindborg
Posted 20 February 2013 - 10:34 PM
I ran 2.25ishL with no breather pipe... ok sometimes when kicking her head in you could smell/ see the oil but for day to day it was never noticeable :lol: Drain, fill with 2LMin (leave level bung in). Job done.
#9 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 20 February 2013 - 10:50 PM
If you drop the rear tray the level plug is very visible, I just got a syringe and put another 400ml in :)/>
I'm sure its not that visible. I think its against an engine mount or the subframe. Either way when I did it it as easier to drain the oil and replace it with fresh stuff, measure just over two litres and happy days.
#10 Paulus H
Paulus H
  • 2,063 posts
Posted 21 February 2013 - 12:31 AM
Where is the best place to get the breather kit? Kind regards, Paul
#11 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 February 2013 - 12:37 AM
Pro Alloy/MMG
Edited by Bumblebee, 21 February 2013 - 12:51 AM.
#12 Bumblebee
Bumblebee
  • 7,592 posts
Posted 21 February 2013 - 12:50 AM
Edited by Bumblebee, 21 February 2013 - 12:50 AM.
#13 MrSimba
MrSimba
  • 5,197 posts
Posted 21 February 2013 - 04:04 AM
Definatly would not try it without a syringe and length of silicone pipe to top the oil up, no way you'll pour anything through the level hole!
But if you've got that it'll take you longer to remove the diffuser than top up the box! :)
Edited by MrSimba, 21 February 2013 - 04:05 AM.
#14 GeorgeBC
GeorgeBC
  • 3,138 posts
Posted 21 February 2013 - 05:57 AM
I meant to remove the level plug is a ball ache its easier to start from scratch and know how much your putting in.
#15 MrSimba
MrSimba
  • 5,197 posts
Posted 21 February 2013 - 07:36 AM
Always found level plug quite easy to remove doubt you'd get a socket on it but a long 8mm hex key is all good :)
