Mr2 Mk2 - Shed / Daily Driver / Track Nail
No replies to this topic
#1 Rosssco
Rosssco
  • 4,185 posts
Posted 21 February 2013 - 01:43 PM
I thought I'd punt this on here to see if there's any interest in some suppa cheap mid-engined fun :) Need to get rid in the next week, or I'll break it for bits just after that (CBA TBH).
I'll get the crappy iPhone pics up tonight hopefully..
1996 P-Reg, Rev 4, G-Limited. Tintop (rarer, slightly lighter JDM-only tintop model with twin airbags)
For sale is my Rev 4 N/A which is used as my daily driver, and has been very reliable in the past ~5 years of owning it. Mileage: ~122k
Partial Service History – I have serviced the car my self in recent years (don’t trust many local garages!) with only suspension alignment done by garages for obvious reasons. Oil / filter changes every 5-6k miles. Oil and filter and air filter will be changed prior to sale. Brake fluid replaced a couple of months back.
Mot: 6 months
Tax: 2 months
Colour: Sonic Shadow
Modifications:
Drilled / grooved discs
EBC Green stuff pads
Braided brakes hoses
Enkei RP-01 Light weight wheels:
16x7" Et35 / 16x8" ET38 (structurally sound, just need a paint refurb)
Tyres:
205/45/16 Eagle F1 - Front (~4mm)
225/45/16 Khumo KU31 (~3.5mm)
Not so good bits:
The car was suffering from corrosion to the bottom of the drivers door. However, the sills have now started to bubble allong the underside, and one of the front wings has a few spots of rust appearing. I do regularly jack the car up on the sills, and so far they appear to be structurally sound, so I'm unsure if the corrosion is internal or external in origin.
I previously painted the black rubbing strips on the side of the car. This was fine initially, but now looks more grey than silver! Fine from a distance, but close up its a bit obvious. Other than that, a few minor pin dents and scratches, although nothing major here either, and totally representative of the 15 years this car has under its belt! The car has never been bumped or damaged by me, and no evidence of this ever having happened, so totally straight in that respect.
The Aircon doesn’t work, as the pump bearing went a couple of years ago, so I simply removed the drive belt. All the hard ware is there, and aircon pumps are available cheap. The electric aerial is intermittentt in operation.
The gearbox shifts / selects gears fine, although has a bit of a whine. Its not excessivly bad (and not unusual), and sounds like the clutch release bearing, although the clutch operation is ok.
I have noted the front drivers tyre is worn on the edges. Still ok to use, but dosn't have lots of life left.
Overall she drives well, but probably more suited to a clean up and use as a fun daily driver or a track car.
Price: £500 ovno
