Rear Toe Link
Posted 08 March 2013 - 07:06 PM
Posted 08 March 2013 - 07:33 PM
Posted 08 March 2013 - 07:45 PM
Posted 08 March 2013 - 07:51 PM
Should have said the passenger side has already been replaced at some stage, not by me, car has done 70k
Hmm. Hard to say, my toe links managed 70k before I replaced both, although they both clearly needed doing. There's so many sources of squeaking though, could well be a ball joint.
Posted 08 March 2013 - 08:05 PM
Posted 08 March 2013 - 08:13 PM
Out of interest, where did you get your toe link from? Autovaux seem to be out of stock.
Thanks
Only of the NA ones. I think they've still got the turbo ones.
Posted 08 March 2013 - 11:22 PM
Posted 08 March 2013 - 11:27 PM
Edited by rob999, 08 March 2013 - 11:27 PM.
Posted 08 March 2013 - 11:32 PM
I didn't realise NA/turbo toe links were different but can't find either on autovaux. EliseParts seem expensive for OEM style links so was wondering if there was another source?
Krusty - Given the consequence of a toe link failing, if there's any doubt it's probably worth replacing.
I did some man maths and got the elise shop uprated ones. Last time I checked the autovaux ones were 70 + VAT each, so call that £168. The uprated ones were £245 inc VAT so only a £80 difference. The way I see it that £80 will be regained in a couple of years where I just need to change the ends at £40 each.
Posted 08 March 2013 - 11:34 PM
The Uprated ones are the ones you want because you have 888's also HCB might need replacing.. Elise shop or parts have very similar kits and only a bit more expensive then standared
Posted 09 March 2013 - 12:13 AM
Posted 09 March 2013 - 09:32 AM
Posted 09 March 2013 - 10:15 AM
Edited by fezzasus, 09 March 2013 - 10:15 AM.
Posted 09 March 2013 - 03:20 PM
Posted 10 March 2013 - 12:33 PM
Old Vs New
See a few snap while on the roads, hello Kerb...
Posted 11 March 2013 - 12:25 AM
Posted 11 March 2013 - 06:53 AM
Posted 11 March 2013 - 08:52 AM
Reasons for changing them...... Mine snapped while round clearways at Brands..... hello kitty litter...
Old Vs New
Have you had any trouble with that set up? There's still play in mine despite several refits.
Posted 11 March 2013 - 08:54 AM
The photo I added shows the wheel hub side snapped.... I track my car with AD08's fitted.
That happened while hard cornering
how often do people check the nut for tightness , at a minimum everytime you have the brake disc off
