Posted 10 April 2013 - 08:42 PM
Posted 11 April 2013 - 07:45 AM
Posted 11 April 2013 - 07:50 AM
Posted 11 April 2013 - 07:51 AM
Posted 11 April 2013 - 07:53 AM
Posted 11 April 2013 - 07:59 AM
If you look in the back of your Blue Book, you may be able to find a scrutineer near you - normally they are happy to help clarify.
Posted 11 April 2013 - 08:07 AM
Edited by Boombang, 11 April 2013 - 08:07 AM.
Posted 11 April 2013 - 10:44 AM
Push fit with Jubilee clips are fine, rubber piping is fine. If the BB doesn't say you can't do something you can.
Are you aware of 10 Tenths forum? I don't spend any time there myself, but it's populated by racers and officials who will answer those last minute questions.
Bits of Blue Book you need for this:
Section J
5.2.1.
Be fitted with bodywork including a driver (and passenger) compartment isolated from the engine, fluid
filled batteries, gearbox, hydraulic reservoirs, transmission shafts, chains, belts and gears, brakes,
road wheels, suspension components including their operating linkages and attachments, petrol/fuel tanks,
oil tanks, water header tanks, catch tanks and fuel system components (other than where such
components comply with J5.13.1 and J5.13.2) such as to prevent there being a hazard
INSERTED BY ME - swirl pot / pump / filter all need to be behind bulkheads or boxed in.
Fuel Systems
5.13.1.
Have any fuel lines passing through the driver/passenger compartment protected and, if non-
metallic, to be internally or externally metal braided hydraulic pressure hose or fuel lines complying with
FIA specifications.
INSERTED BY ME - If you lines are outside the driver/passenger compartment then they do not need to be overbraided.
5.13.2.
They may only be joined by screwed sealing joints or vehicle manufacturers approved joint.
INSERTED BY ME - I read that as if a vehicle manufacturer uses it to join fuel hoses then so can you (Peugeot have push fit as standard to the fuel pump but use the odd compression fittings, not worm drive clips)
5.13.3.
If fitted with fuel fillers in a closed boot, or under closure, have collector/spill trays incorporated to drain
outside the vehicle.
