Rabiata Red Na
Posted 11 April 2013 - 10:01 PM
I only purchased the car a couple of months ago but as it is used as my daily, i have had a chance to get to grips with it now. Love it!
Its a 2.2 NA in Rabiata red. Some pics:
*general inspection and clean up
*Fit my new Tullet manifold and hi flow cat
*oil and oil filter
*fuel filter
*air filter
*change the alternator belt
clam off:
Note the precision tool on the rear frame.
Upon inspection it was just aswell i was replacing the manifold! To be honest i was expecting to find a crack here as the last service work reciept had an advisary for a slightly blowing manifold.
exhaust system off, not much of a job, only had a bit of a delay on one of the old manifold studs, not wanting to come out, but got there in the end.
New Tullet manifold and 200 cell cat thanks to James who sorted the group buy on here
All fitted with new studs, gaskets, and bolts.
Standard back box on for now, i think i want to stick a Larini on there, and then have to change it over to standard for track days.
50:50 after giving the rocker cover a bit of a polish and tidy up.
Coolant tank bracket before:
and after, also fitted a gear box breather filter on there, and have a piece of carbon fiber cut out to use as a uv cover(not pictured):
Thats where im up to now, picking up new seals tomorrow so i can change the oil filter and hopefully my new fuel filter and alternator belt will be here so i can get them fitted too.
After this write up i now have even more respect for the guys who do long and detailed write ups/guides, as believe it or not this has taken me ages lol
Ian
Posted 11 April 2013 - 10:05 PM
Posted 11 April 2013 - 10:08 PM
Posted 11 April 2013 - 10:11 PM
Posted 11 April 2013 - 10:14 PM
Posted 11 April 2013 - 10:17 PM
nicollow i have put the standard back box heat shield on (not pictured) although because it has seen better days i would like to make my own, do you have any pictures of what you have done for heat protection of the clam?
Ive not got any yet, but probably will do by tomorrow. Try searching for "nimbus heat shield" or somit for photos...
I ceramic coated my manifold but it still kicks out a sh!tload of heat:
http://www.vx220.org...ta/page__st__40
Posted 11 April 2013 - 10:18 PM
Posted 11 April 2013 - 10:21 PM
Posted 11 April 2013 - 10:26 PM
Posted 11 April 2013 - 10:28 PM
Posted 11 April 2013 - 10:29 PM
Prob be fine while na .
Martin's car and mine were NA (if highly tuned) at the time.
Posted 11 April 2013 - 10:30 PM
Edited by badgerade, 11 April 2013 - 10:31 PM.
What do you mean by realling? tighten it up? will that take the sag out of the middle front?
yes.
Posted 11 April 2013 - 10:37 PM
May just be the angle, but the cabling looks like it may foul on the gear selector in that last photo?
Its the angle, i checked that it didnt foul in any of the gears after fitting. good spot though.
Posted 16 April 2013 - 12:07 PM
