Rabiata Red Na
#41
Posted 26 January 2014 - 11:37 AM
#42
Posted 31 January 2014 - 10:11 PM
Todays work consisted of rebulding the rear suspension, car has looked bare for a while, so it was good to see it all back together. I also replaced the small neoprene sheets that go between the bottom of the chasis and the solid brake lines, and the sheer panel and handbrake where the cable forks off as the orginals were starting to come away.
The clips that secure the brake line to the chasis were damaged, so i got some that i thought were the same but they dont want to stay very tight in the hole in the chasis. Anyone know the correct clip i need? its the white clip in the pic below along with one of the old neoprene sheets.
Anyway this little lot arrived, stainless nut and bolt kit and new nuts/bolts for wishbones and dampers.
By the time i was packing up it was dark but still took a quick snap of the progress
Tomorows job list is to bleed the brakes/clutch, fit my larini exhaust and then see if it will start after its hibernation!
#43
Posted 07 February 2014 - 05:34 PM
#44
Posted 07 February 2014 - 10:04 PM
#45
Posted 10 February 2014 - 11:18 AM
Yea used rattle cans, just used halfords grey etch primer, then silver spray paint,
Be careful not to get petrol on the paint as it will strip all your hard work unless you got petrol resistant laquer.
#46
Posted 10 February 2014 - 06:13 PM
#47
Posted 11 February 2014 - 03:38 PM
Didn't use any clear coat, just the colour. Seems quite durable but I'm not going to dip it into petrol to find out lol
Best not..
#48
Posted 18 February 2014 - 10:35 PM
Subframe all back together, note the nice shiny freshly painted shocks, look great, however after taking them apart to paint and fit the new spring colars one of them has sprung a leak. I was worried this would happen when messing with them however it would have probably only been a matter of time before it went anyway. So thinking nitrons all round now...?
Chucked in a fresh air filter:
As it stands now after refitting everything and tidying up the exhaust heatshield and re-riveting:
Plans now are to:
*New suspension, thinking some sort of Nitrons
*New tyres
*Tillet B5 seat to go in, need to sort a harnes and bar
*Bodywork repair, ive started filling some small cracks and chips
*Paint
#49
Posted 19 February 2014 - 09:14 AM
#50
Posted 19 February 2014 - 10:50 AM
#51
Posted 19 February 2014 - 11:07 AM
#52
Posted 19 February 2014 - 03:34 PM
#53
Posted 21 March 2014 - 06:08 PM
More progress:
Cleaned up undertray, before:
After:
Removed side vents, paint peeling and metal is corroded, will get these podercoated.
Have fitted new seat. Tillet B5
Have it as far back and low down as i could get it.
As the seat is so far back i needed the track version of the harness bar from Jon Betts, fitted that today.
These turned up yesterday, Yokohama S Drive in 195/45/17 and 225/45/17
#54
Posted 21 March 2014 - 09:32 PM
#55
Posted 22 March 2014 - 01:04 AM
#57
Posted 23 March 2014 - 05:40 PM
Are you fitting the S Drive to std wheels? If so can you get some pics of them fitted to the wheel please. Liking the B5 seat as well.
Yep they are going on the standard wheels. what is it you want to see specifically?
Are they the xl ones? I had the xl ones on the front and they were excellent, but could only get the normal ones on the rear and the sidewalls were quite a bit softer which meant you leant into them a little more.
The fronts are, rears are not. how did you find the balance?
How did you do that?
By spending far too much time on it than i probably should... cleaned about 10 times with wheel cleaner and a brush, then a mixture of sandpaper, scraper, and polish.
#58
Posted 23 March 2014 - 09:22 PM
#59
Posted 24 March 2014 - 05:16 AM
The equal amounts of grip but there was a bit of lean onto the tyres on the rear. Before I got the rears I had ku31 xl on the rear and the s-drives on the front. The balance was great, nice grip in the wet and the wear on the rubber was minimal. Wrightstuff said he wouldn't be anywhere near me on track because obviously I was going to come flying off at the first corner because I had 2 different brands front to rear. I would have preferred if they had done xl rears to be fair, but I drive differently to others so see how it feels to you.The fronts are, rears are not. how did you find the balance?
#60
Posted 24 March 2014 - 05:20 AM
Don't know if you can see this:Would like to see how much the tyre hangs over the rim compared to the std 175 tyres.
