Oil Viscosity - Why More Isn't Always Better
12 replies to this topic
#1 fezzasus
Posted 12 April 2013 - 12:01 PM
Increasing oil viscosity is often banded about as a fix-all solution to many concerns, including:
  • Blue smoke (oil getting past valve seats/piston rings)
  • High oil loss
  • Regular track usage
Here i'm going to try to explain why there's a lot to it than just going thicker and why a thicker oil may not give you the results you want or expect.
Engine oil is composed of an additive package, a viscosity modifier (to reduce the amount the oil thins at high temperatures) and usually two or more base stocks. These base stocks come in different grades:
Group I - these are the least refined, they have high sulfur and permanently thicken the quickest.
Group II - these have been refined to remove some sulfur, however are still relatively low quality, not used much in Europe
Group III - these have been significantly refined to remove sulfur and reduce high temperature oxidation (causing thickening). In some places these are referred to as synthetic due to the number of chemical processes undergone to produce the base stock.
Group IV - these are synthetically made and are tightly controlled, they have minimal sulfur and are very oxidatively stable.
Group V - this group refers to everything else available as a base stock, such as esters. They tend to be expensive and with properties similar to that of group IV.
Mineral oils are just a mix of different length hydrocarbons, as the refinement process gets better, the molecular weight distribution (the number of different lengths) reduces, this makes the base stock properties more predictable.
As you may have guessed from reading this, the price for the base stock increases as the group increases. Companies want to price optimise their products so put as much of the lowest quality material they can in. They combine multiple base stocks to target the correct viscosity (in simple terms, if you want a viscosity of 5, and have only base stocks of 4 and 6, you combine both at equal ratios to get the target viscosity). This graph illustrates the resulting situation.
However, there are factors stopping low quality base stocks being used, as oils get thinner, more of the thin base stock molecules get boiled off as the oil is heated, this means great viscosity increase (as without the thin material, the oil gets thicker) and regular top ups, here - everything marked in red is lost, this amount of loss in unacceptable and will fail engine tests (for requiring too many top ups, and resulting in large viscosity increase as the thin base oil is constantly being lost), as well as bench criteria (the oil is heated overnight and weight measured, high loss is a fail). Companies solve this by switching to a higher quality base stock, the overaIl viscosity stays the same, but the amount lost when heated reduces.
direct comparison:
The problem is the viscosity requirements don't change much with viscosity grade, so if the company wanted to produce a higher viscosity grade oil (in this case go from a 5W-3 to a 15W-50 oil), they can switch back to the poor quality base stock without much concern (before they were targeting a viscosity of 5 with base stocks of viscosity 4 and 6, now they are targeting a viscosity of 7 with base stocks 6 and 8). This means that in practice, oil quality has potential to get worse when moving to a higher viscosity grade as the limits don't move, so allow for worse base stocks.
If you want to ensure you have good quality base stocks (which will limit oil loss through evaporation), then look for specifications which tighten the oil loss limit. Daimler MB229.5 has a limit of 10 % respectively compared to the 13 % as an industry standard (effectively moving the red line on the graphs to the left).
I hope this helps.
Edited by fezzasus, 12 April 2013 - 12:04 PM.
#2 vocky
Posted 12 April 2013 - 12:15 PM
you are far too clever :P
#3 JG
JG
  • 13,617 posts
Posted 12 April 2013 - 12:16 PM
thumbsup Imnotworthy This is what you were trying to explains to me the other day :)
#4 fezzasus
Posted 12 April 2013 - 12:18 PM
Yes, partly why I wrote it. Unfortunately for you I had a combination of red wine and my ipad, which made graph drawing difficult :happy:
#5 Dave E
Dave E
    I LOVE SNETTERTON
  • 3,116 posts
Expertly explained and full of FACTS, now you know that isn't the way things are done round here :rolleyes: Thanks all the same for actually taking the time thumbsup
#6 J4EY D
J4EY D
  • 3,236 posts
Posted 12 April 2013 - 01:47 PM
Great read!! I just ordered some higher viscosity oil this morning, the Castrol 10w60 BMW stuff :)/>
Edited by J4EY D, 12 April 2013 - 01:48 PM.
#7 chris_uk
Posted 12 April 2013 - 01:51 PM
have you got the lap times to prove it tho..
#8 slindborg
Posted 12 April 2013 - 03:02 PM
Can you sell me something?
#9 fezzasus
Posted 12 April 2013 - 03:05 PM
Nope. I don't even get any oil myself.
#10 fezzasus
Posted 12 April 2013 - 03:06 PM
Actually, that's not true. I got some free oil when I volunteered my old shed to test an oil with 'catastrophic' cam wear.
#11 slindborg
Posted 12 April 2013 - 03:16 PM
If you arent selling something, then frankly thats a load of lies.... :lol:
#12 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 12 April 2013 - 03:25 PM
F U slindbog
#13 slindborg
Posted 12 April 2013 - 03:40 PM
F U slindbog
:wub:
