What Voltage Should I See At The Fuel Pump?
Posted 12 April 2013 - 06:43 PM
Posted 12 April 2013 - 10:00 PM
Posted 12 April 2013 - 10:55 PM
according to this, they are 1mm, C=black=gnd, B=brown/grey=pos but sometimes those colours in the tis are wrong
If you are using a multimeter it will tell you if the voltage is negative or positive depending on which way around you connect the black/red probes
You will only see voltage there briefly when you turn ignition on (2-3 secs), or when engine is cranking/running
The other 2 wires are for the fuel level sensor which are apparently D=black and A=green/black and 0.75mm http://www.speedster...m/Instument.pdf
edit: it does say the connector
Edited by rik, 12 April 2013 - 11:00 PM.
Posted 13 April 2013 - 06:52 AM
Posted 13 April 2013 - 07:08 AM
Edited by Nev, 13 April 2013 - 07:09 AM.
Posted 13 April 2013 - 07:13 AM
http://www.vx220.org...-the-fuel-pump/
Posted 13 April 2013 - 07:21 AM
Posted 13 April 2013 - 07:44 AM
Posted 13 April 2013 - 08:58 AM
When I put my metre across 30 and 85 i get 4v, across 86 and 85 I get 4v. However if I put the metre across either 30 or 86 and an external earth I get the same voltage as the battery is holding.
So should I just try and run another earth to no 85 on the relay?
Posted 13 April 2013 - 09:11 AM
Posted 13 April 2013 - 09:14 AM
Posted 13 April 2013 - 02:51 PM
Am I right in thinking that the fuel pump relay is the 2nd from the left?
I seem to have lost all voltage at the relay conections. Tried to see if I could get a voltage reading from the crash switch but there doesn't seem to be any there (my skills with a multimeter leave a lot to be desired).
Still seeing between 4-5 volts at the pump(battery is now charged)....
Now i need to either try and get the car to an auto electrician or find a decent mobile guy.
Posted 13 April 2013 - 06:15 PM
With 10v at the battery, that is a very weak battery. I wouldn't be surprised at some V losses between the battery and pump. Get the battery charged and then check it.
Hi Lou,
Save yourself some time chasing your tail........low battery voltage on the VX seems to throw up loads of anomolies when you're trying to isolate a fault and nothing seems logical. Charge/replace the battery then stert fault finding if neccessary.
Good luck.
