Basically, the car won't start. It churns over but won't fire. This is what the opcom thing says: -
When I clear the errors and try again they pop right back up. There are no other errors.
I have removed the loom of doom connection, sprayed it with contact cleaner, let it dry and put it back together. Doesn't mean I did it properly. The crank position sensor has also been changed.
Looking through previous threads with this error I get injector failure,
This thread annoyed me. Forum member gets lots of help from others, obviously gets it fixed but doesn't bother to report back on how it was fixed.
This thread was very helpful, and the start of my diagnosis.
Looking at the error message it's clear fuel pressure is the problem. Pressing the bleed valve on the injector rail showed no fuel coming out.
When I turn the ignition on I do hear a click, but that's it, none of the usual whiring sound that goes on for a second or two.
I've checked the fues in the boot and all are ok and look in good condition.
Currently I have the relays out and am waiting for the contact cleaner to dry before putting them back in.
One thing I did notice is when I took the yellow Lotus relay out (the starter inhibitor I think) the fuel pump made it's usual whirring sound for a second.
Anyone with any tips please chip in.
