Standard Seat Belt + Harness?
Posted 10 May 2013 - 08:28 AM
Posted 10 May 2013 - 08:30 AM
Posted 10 May 2013 - 08:50 AM
Sector 11 or Hanger 11 or whatever there called do a kit that will allow you to run it. Its pricey for what it is but does the job, and makes getting the seatbelts done up a bit more fiddly but that's fine for me & I probably drive 90% harnesses' and 10% seat belts..
Posted 10 May 2013 - 08:53 AM
Posted 10 May 2013 - 09:02 AM
Its basically a set of longer bolts, with a larger 'smooth' section as such where both the end of the harness & seat belt can both fit too separated by a larger spacer. The passenger side one was a bit different as your required to lock two nuts together on the bolt to put it in - can't exactly remember why
http://www.sector111...ss_hardware.cfm - The kit
http://www.sector111.../harnesskit.pdf - Fitting instructions
Posted 10 May 2013 - 09:18 AM
My schroth and oem´s are connected via the oem bolts.
But as i also have grinded away the headrest spoons, so i could die a horable death any day now.
I really need to extend my fuelpump access hole for the full effect.
Edited by smiley, 10 May 2013 - 09:19 AM.
Posted 10 May 2013 - 09:31 AM
Posted 10 May 2013 - 10:32 AM
Posted 10 May 2013 - 12:28 PM
Thats what I want!I run both
Posted 10 May 2013 - 12:41 PM
I also run both using just the existing hardware. I think the only trade off is that the belt sockets are now fixed in a more upright position (or at least very hard to pivot as before) Clearance to the center console is unaffected -
Posted 10 May 2013 - 01:52 PM
Those corbeau look to sit alot lower than standard seats. Do they fix straight onto the original subframes or bolt straight in? Do they just start lower down so provide as much 'seat' as oem?
Posted 10 May 2013 - 03:11 PM
lost the rear crumple zone.
Nothing wrong with that. Very bouncy by design.
Tested that on my first trackday.
Posted 10 May 2013 - 06:08 PM
Posted 10 May 2013 - 06:42 PM
