Where Exactly Is The Upper Gear Oil Plug?
Posted 12 May 2013 - 04:11 PM
I've taken out the centre console to see if anything (new seats) was fouling the cables and that all looks fine.
I've followed the cables all the way back to the gearbox and everything looks to be in good order.
Next I was going to top up the gear oil (as I don't think I have enough for a full change) but I'm not sure where the plug is.
The bottom plug was easy to find, but I'm not sure if I've found the top one.
I have stuck some pliers in the plug to illustrate where I think it is.
Top view
Side view with pliers
Side view without pliers
Am I in the right place?
Posted 12 May 2013 - 05:13 PM
yes that is the filler plug
Edited by vocky, 12 May 2013 - 05:13 PM.
Posted 12 May 2013 - 05:19 PM
Posted 18 May 2013 - 09:18 PM
Posted 27 June 2013 - 10:28 AM
Can anyone advise how to disconnect the gear cables from the gearbox?
I still have a stiff change and I'm guessing/hoping it's the cables and nothing to do with the box, so if I can disconnect the cables I should still have resistance to the gear stick movement.
Posted 27 June 2013 - 10:35 AM
Suitably sized spanner inserted underneath the balljoints and just lever up and they should pop off quite easily.
Posted 27 June 2013 - 10:43 AM
Ta. Presumably just as easy to get them back on (in the right order of course)?
Yep, last time I did it they push on by hand without much effort.
