Turbo Ears On Na
13 replies to this topic
#1 RYN
RYN
  • 489 posts
Posted 15 May 2013 - 07:04 PM
I am in the process of fitting these to my na have got everything ready and trial fitted but when the ears are on the car I wanted to see if people secured the ears to the grill in some way as it looks like there should maybe be a lip on. The ears to keep them in place ? The ears are not vauxhall made I had then from a member on here can't remember who it was now been a while. Thanks for the help in advance
#2 smiley
Posted 15 May 2013 - 07:48 PM
Grills are tigersealed to the ears.
The set is then secured to the car with 4 screw constructions, just like in the real turbo.
#3 RYN
RYN
  • 489 posts
Posted 15 May 2013 - 08:29 PM
Right ok thanks didn't think the grills were going to have to be tiger sealed to the ears thanks for clearing that up. I thought they stayed seperate for removal for painting etc if needs be at some point
#4 RYN
RYN
  • 489 posts
Posted 15 May 2013 - 09:05 PM
I'm also finding there is quite a big gap at the top of the ear where it meets the clam on the drivers side?? Is this a common problem with these grills that aren't oe
#5 Bumblebee
Bumblebee
  • 7,592 posts
Posted 15 May 2013 - 09:11 PM
It's not the first time I've heard this with the aftermarket ones
#6 smiley
Posted 15 May 2013 - 09:55 PM
I only heared of aftermarket ears, not grills.
Did you get them for cheaps on ebay? (these polish replica´s are known to be horrible)
Put up some pixies of what you got. Makes life easier guessing here.
Edited by smiley, 15 May 2013 - 09:56 PM.
#7 Bumblebee
Bumblebee
  • 7,592 posts
Posted 15 May 2013 - 09:56 PM
My mistake I thought you was meaning the actually ears
#8 MartinS
MartinS
  • 5,173 posts
  • Interests:Track days
    Pubs
    Sausages
Posted 16 May 2013 - 07:57 AM
Dont tiger seal them on. I got some fix on bolts after following coco pops guide. which means I can take mine on and off when I want.
I too had a gap but with some adjustment you can really minimise it, or attach something esle and paint it balck to block that hole. Just be acreful not to cut too much out of the original hole when fitting them.
Fitted mine a month ago and all good.
Martin s
#9 CocoPops
CocoPops
  • 17,182 posts
Posted 16 May 2013 - 08:02 AM
Yep, I have OEM ears and there was a gap allowing movement up and down, so I moved them up to leave the gap at the bottom (unseen) and closed the gap at the top.
#10 RYN
RYN
  • 489 posts
Posted 16 May 2013 - 04:05 PM
Sorry for the confusion I have oem grills but the ears themselves are reproduction items I had then from a member selling them on here but can't remember who was making them now . I have followed the guid on here and haven't tiger sealed the ears in to place I have tiger sealed some fiber glass fixings into the rear of the clam to bolt the ears to. What I was unsure of is do I need to tiger seal the grills to the ears them self as I can't see how these are going to stay in place ??
#11 techieboy
Posted 16 May 2013 - 04:15 PM
Yes, Tigerseal the grills into the ears. thumbsup
#12 jonnyboy
jonnyboy
    The hardtop guy
  • 8,290 posts
Posted 16 May 2013 - 04:24 PM
Not mine. Sounds like the same problem with the LM Corse ones that are also too short (Which I dont sell for that reason) Its hard to know how they actually ended up too short maybe there was a design revision at some point?!
#13 RYN
RYN
  • 489 posts
Posted 16 May 2013 - 09:43 PM
Thanks for the help guys much appreciated I will tiger seal the grill to the ears then. I just thought everything needed to stay seperate if they needed reprinting at some point down the line. Jon I have sent you a pm regarding ears
#14 smiley
Posted 16 May 2013 - 10:19 PM
Nah, 2 screws go into the grill section to the sill, and 2 in the ear section.
So they have to be bonded together somehow.
If in need of a respray, take them off the car and the painter (or you) needs to mask off the grill part.
Anyhow easier then dropping off the complete car, as painting in place is more open to dripping effects, and the sanding results gets everywhere.
Edited by smiley, 16 May 2013 - 10:19 PM.
