The trailing edge of my front bonnet bounces about when I'm driving, but it is flush when stationary. Can this be fixed?
Bouncing Bonnet
Posted 10 June 2013 - 05:08 PM
Posted 10 June 2013 - 05:11 PM
Yeah, adjust the stops and the latch spring. Its a ball ache but you can do it.
Posted 10 June 2013 - 05:34 PM
I know about the stops, and they keep the bonnet flush when stationary, so I can't raise them. So what do I need to do with the latch spring?
Posted 10 June 2013 - 05:35 PM
slacken the locking nut then screw the peg in a turn a t a time try to mark exactly where it was on the bonnet or it either won't shut or won't openI know about the stops, and they keep the bonnet flush when stationary, so I can't raise them. So what do I need to do with the latch spring?
Posted 10 June 2013 - 05:39 PM
Makes no sense sitting here. Best I go outside and have a look. Good tip about the locking wheel nut!
Posted 10 June 2013 - 05:44 PM
If you look at the centre of the spring you'll see it's got a flat head mark on it. Take a screw driver and tighten it a couple of turns.
Posted 10 June 2013 - 07:12 PM
Bollox.
Loosened the big locking nut off, and the mechanism shifted all over the flamin place!! There was no way in hell that spring was going to screw in, even with a very large screwdriver. Nearly went through the bonnet trying.
So gave it up as a bad job, tightened the locking nut back up, and closed the bonnet. Will it open? Will it fcuk!! Even with judicious raging on the bonnet.
Sometimes I should just get 'people' to do these things
Posted 10 June 2013 - 07:21 PM
Posted 10 June 2013 - 07:54 PM
Stick a bit of velcro on top of stops and on underside of bonnet. Worked for me.....
Posted 10 June 2013 - 10:14 PM
Posted 10 June 2013 - 10:26 PM
Have you tried raising the 2 stops at the front of the bonnet lifting the front up a bit and this might force the screen edge of the bonnet down.
Posted 10 June 2013 - 10:43 PM
Bollox.
Been there mate, fun it aint , if you need someone to pull the bonnet give us a shout I cant be that far away,
I had the other half to help me something I have never asked for again!!!!
Edited by wantsum, 10 June 2013 - 10:44 PM.
Posted 10 June 2013 - 11:03 PM
Hi Horace,
Definately try the two people approach to fully pull the cable/latch oped, while you jiggle the bonnet around to free it up.
I had the same issue with mine after I'd messed around with it. Centre pin adjustment was the fix for me:
http://www.vx220.org...t-sssshiverrrr/
- good luck, hope it opens up sooner rather than later.
Posted 11 June 2013 - 08:01 AM
I wish I'd waited...
Velcro and adjusting the front stops (which I didn't know existed) would have been a much less stressful solution.
The fact still remains that the centre pin would not screw in. Do I just need a bigger bigger screwdriver and risk shearing it off?!
Posted 11 June 2013 - 08:14 AM
Did you loosen the locknut first ?I wish I'd waited... Velcro and adjusting the front stops (which I didn't know existed) would have been a much less stressful solution. The fact still remains that the centre pin would not screw in. Do I just need a bigger bigger screwdriver and risk shearing it off?!
Posted 11 June 2013 - 10:51 AM
Problem with velcro is it wont last, and has difficulty sticking to the rubber stops,
you could always try to push (bend) the locking plate down a bit so the center pin
locks slightly lower, I tried everthing on mine even fitted a new center pin, in the end
rasing the rubber mounts cured mine, no issues now.
I even considered fitting allen key bolts the edges like the elise s2's have.
Edited by wantsum, 11 June 2013 - 10:52 AM.
