What Air Filters Do People Use For Tuned Turbos?
15 replies to this topic
#1 P11 COV
P11 COV
  • 7,683 posts
Posted 23 June 2013 - 09:12 PM
I had a look at my air filter today. I am embarrased to say this is the first time since I've had the car (5 years?) :blush:  :blush:  :blush:
Anyway, as you can imagine it was pretty horrible. It is an ITG foam one.
What should I do? Can I wash this one. Will a standard filter do the job just aswell? I think the Airbox is a modified Coutenay one - it seems to have an extra hole in it.
I have  a BMC CDA airbox which I did use on my last turbo mnay years back. I am wondering about trying this out again.
#2 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 23 June 2013 - 09:13 PM
DG airbox using standard filter :)
#3 techieboy
Posted 23 June 2013 - 09:14 PM
Yes, you can clean it and lightly re-oil it, if you can be arsed.
#4 Dave H
Dave H
  • 234 posts
Posted 23 June 2013 - 09:27 PM
I have a GM paper filter in my modified airbox and its good for the other side of 400 BHP. Good filtration as well. Dave
#5 P11 COV
P11 COV
  • 7,683 posts
Posted 23 June 2013 - 09:33 PM
I was inclined to think that myself.
#6 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Posted 23 June 2013 - 09:51 PM
Standard paper filter all day long.
#7 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 24 June 2013 - 06:44 AM
Yeah that.
#8 siztenboots
Posted 24 June 2013 - 07:46 AM
the problem with the standard filter is only a very small part of its surface area gets used by the airbox
I use [font="'times new roman', serif;"]K&N RC-3690  , this is good for plenty of bhp[/font]
[font="'times new roman', serif;"]to give you some idea of size[/font]
[font="'times new roman', serif;"]Posted Image[/font]
#9 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 24 June 2013 - 08:12 AM
Steve, is that your car ?
Is that a oil cooler fitted?
#10 siztenboots
Posted 24 June 2013 - 08:18 AM
not my car , the black bit is the side sill , this is carstens ( cs_ ) monster car , something like 380ps
#11 P11 COV
P11 COV
  • 7,683 posts
Posted 24 June 2013 - 05:33 PM
I use K&N RC-3690  , this is good for plenty of bhp
K &N site says that's a cotton gauze filter. Do they need to be oiled or is that's just the foam ones. If so what's the maintainence required on the K &N?
#12 Bumblebee
Bumblebee
  • 7,592 posts
Posted 24 June 2013 - 05:47 PM
Apexi filters are good and there a dry filter,so pretty much maintenance free
Edited by Bumblebee, 24 June 2013 - 05:51 PM.
#13 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 24 June 2013 - 05:58 PM
our right steve, thats is he case of the oem box setup, Dave handy work removes that
Sure when I was round ITG Andy confirmed the surface area of the oem filter test flowed 438bhp or 458bhp before restriction. Cant remember which for sure.
clearly filtration better than any aftermarket filter
Run an Apexi on my track beastie (SR20DET powered) and seem to flow well but dont care about filtration due to track use only and it sticks out the side of the bonnet LOL (no room under bonnet) it does however seem to be better than a lot of the other jap options :)
Also depends on volume of intake you lik between the modded air box vs apexi - the apexi made good power on George BC car on standalone
DG
#14 Speedy_GL
Speedy_GL
  • 2 posts
Posted 27 June 2013 - 10:40 AM
I use one of these filters!
http://www.greenfilt...CC=11&PTC=AFG17
Air Filters (Univ Twin Conical Silver)
Attached File  post-739-0-68662300-1315479056.jpg   64.58KB   4 downloads
Attached File  post-739-0-54566700-1315479148.jpg   128.61KB   4 downloads
Attached File  ansaugung.jpg   71.32KB   4 downloads
Attached File  post-739-0-10981100-1331337534.jpg   89.73KB   4 downloads
Edited by Speedy_GL, 27 June 2013 - 10:50 AM.
#15 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 27 June 2013 - 12:21 PM
I am running the Apexi and I cant praise it enough. Sounds absolutely awesome - Lots of sucking :dry: - if only home life could be this good! I also think that the engine runs smoother under boost ith  mod. Jon
#16 P11 COV
P11 COV
  • 7,683 posts
Posted 27 June 2013 - 10:09 PM
Well for the moment I have put a BMC carbon dynamic Airbox on it. I found it gathering dust in my garage from my last VXT. It feels smoother but i cannot work out whether it is or whether it has lost me power. It's certainly quieter than the modified standard air box.
