Car Ramps
21 replies to this topic
#1 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 26 June 2013 - 06:49 PM
I need some, there are the usual steel frame with the extenders but I found these.
Seem a bit pricey but look alright.
http://www.amazon.co...ywords=Car ramp
Still don't think the front will drive up but the rear should, what do you think?
#2 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 26 June 2013 - 07:10 PM
They look ok but expensive for what they are. Just use a normal metal ramp with some wood in front.
#3 techieboy
Posted 26 June 2013 - 08:13 PM
I've got the ProAlloy ramps. Not really of much use but look nice. :lol:
#4 VXT Tim
VXT Tim
  • 11,421 posts
Posted 26 June 2013 - 08:18 PM
I've just spent 30 minutes getting fcuked off and giving myself a headache. I did a level maths ffs. I've been working out the angles and length of the slope and refused to use the 'online calculators' :lol: Pro alloy ramps :D
#5 VXT Tim
VXT Tim
  • 11,421 posts
Posted 26 June 2013 - 08:19 PM
£135 :o They do look nice :D
#6 Zoobeef
Zoobeef
    Joes bedroom assistant.
  • 11,103 posts
Posted 26 June 2013 - 08:22 PM
Make some of these http://www.pistonhea...ic.asp?t=842247
#7 smiley
Posted 26 June 2013 - 08:24 PM
And remember kids, no drinking and ramping. :ninja:
#8 techieboy
Posted 26 June 2013 - 08:28 PM
Freebies. ;)
#9 myles
myles
    Sausagefest
  • 2,089 posts
Posted 26 June 2013 - 08:29 PM
Gulp! I did that with the Mrs' 206. I NEVER use ramps now. Hopefully the VX220 is set up to use axle stands!
#10 techieboy
Posted 26 June 2013 - 08:30 PM
To be honest, I use my homemade chipboard ramps more often as they're higher and with an even more gradual slope to them. But I mostly just use a trolley jack as most things that need the car off the ground also need one or more wheels off.
#11 VXT Tim
VXT Tim
  • 11,421 posts
F***er :D So did you actually want them for anything specific?
#12 techieboy
Posted 26 June 2013 - 08:33 PM
Other than getting the car off the ground? Not really. :D
I have used them plus my homemade ramps to get all four corners off the ground but I usually jack it up and stick how ever many concrete blocks are needed, under the tyres. There's no way I'd ever reverse up one of those ramps as pictured above, in any of my cars - they always look terrifying. :wacko:
#13 JimmyJamJerusalem
JimmyJamJerusalem
  • 10,382 posts
Posted 26 June 2013 - 08:59 PM
Get these 230873563274 (On phone, can't do link)
#14 techieboy
Posted 26 June 2013 - 09:03 PM
I almost bought those 3 or 4 years back. Until I realised I'd need to fcuk about with the front of the car to even get onto them in the first place. :lol:
#15 myles
myles
    Sausagefest
  • 2,089 posts
Posted 26 June 2013 - 09:04 PM
I tried phoning that number but got no answer. Looked a little long!
#16 Sylph Hunter
Sylph Hunter
  • 68 posts
Posted 27 June 2013 - 09:46 AM
I'm selling a pair of long ramps - 25cm height over 180cm length - looking for £75 collected from Cirencester/Swindon area.
More info here..... http://mr2championsh...amps-t2372.html
#17 Nev
Posted 27 June 2013 - 09:48 AM
Tim, you are best off making your own, they would be a lot cheaper, and can be sized/angled to fit your car exactly.
I made my own from a single sheet of 18mm ply from B&Q (for approx. £25). They even cut the sheet into long strips for me for free. Then I simply screwed a few strips together and planed the stepped angle smooth, and screwed on end stops. Took about 1 hour or so. Rewarding, cheap, functional.
I now leave them permanently in the garage and drive the car up onto and leave it parked like that in case I want to tinker at any time. As the angle is so slight going up and down them is no bother. Mine are only about 5 inches deep and are there to allow me to get a jack under the car, you could clearly make you own to suit.
Edited by Nev, 27 June 2013 - 09:52 AM.
#18 VXT Tim
VXT Tim
  • 11,421 posts
Posted 27 June 2013 - 09:57 AM
After sleeping on it last night (after I'd calmed down from my trigonometry induced rage) making my own is the way forward thumbsup.
#19 Nev
Posted 27 June 2013 - 10:05 AM
Nothing like a good bit of rage (and venting it verbally (or better still, physically))!
I spend half my working life enraged by incompetence of others in the workplace. Where I work, the lowest and slowest possible standard and "brushing problems under the carpet" are the de-facto standard, which conflicts with my nature :(
Edited by Nev, 27 June 2013 - 10:07 AM.
#20 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 27 June 2013 - 10:23 AM
PIC
really like the look of this, do you have them fastened to the floor to stop them slipping? Wood on concrete is quite slippy.
When I get my garage I will do something like this I think thumbsup
