High Compression Pistons - Anywhere?
high compression pistons where to buy
38 replies to this topic
#1 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 09:03 AM
I trying to source a set of high compression pistons (11:1). I looked for Wiseco and JE Pistons but can't seem to locate any compatible products. Dropped a line to Coutenay but not something they carry.Anybodyany idea where I could pick up a set? I'd prefer a kit with rings and pins. Standard bore (not me the pistons).
Thanks,
Stephen
#2 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 09:08 AM
The Wiseco pistons are 10:1 with a 1mm thick gasket.
If you install a Z22se gasket which is supposed to be at around 0.5 mm you will end up with a 10.5:1 CR.
Shim your head another 0.5 mm and the job is done.
#3 Rosssco
Rosssco
  • 4,185 posts
Posted 28 June 2013 - 09:09 AM
Z22YH pistons not suitable?
#4 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
  • Interests:Daft plastic cars
Posted 28 June 2013 - 09:16 AM
The Wiseco pistons are 10:1 with a 1mm thick gasket. If you install a Z22se gasket which is supposed to be at around 0.5 mm you will end up with a 10.5:1 CR. Skim your head another 0.5 mm and the job is done.
EFA
#5 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 09:55 AM
Thanks
You can also use a Z22YH head gasket which is around 0.4 mm
Edited by 2-20, 28 June 2013 - 09:56 AM.
#6 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 28 June 2013 - 10:15 AM
0.1mm = 0.1:1 increase in compression ratio?
Sounds too good to be true...
What is the stroke length on the Z22se?
Edited by VXRed, 28 June 2013 - 10:16 AM.
#7 siztenboots
Posted 28 June 2013 - 10:27 AM
94.6mm , according to the conrod ratios thread , http://www.vx220.org...-conrod-ratios/
whats the squish is the next question
#8 siztenboots
Posted 28 June 2013 - 10:29 AM
more information here , http://www.vx220.org...high-rpm/page-2
#9 slindborg
Posted 28 June 2013 - 10:30 AM
That would be overly lucky..
Plus as the head is a dome, knocking 5 *0.1mm off will alter the volume by a lesser quantity each time.
#10 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 10:35 AM
Anybody know?
Prefer not to get involved in any skimming. Head gaskets I can do.
#11 vocky
Posted 28 June 2013 - 10:43 AM
according to the Mad Doc's calculations you can skim 1mm from the head to get 11:1 CR
or just use the 11:1 CR z22yh pistons and rods :sleep:
#12 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 10:46 AM
Do I need the rods vocky? I have some eagles here I'd like to keep.
#13 slindborg
Did he do it and measure it? if not then I'd take that with a massive fist of salt :lol:
#14 vocky
Posted 28 June 2013 - 10:47 AM
rods are not interchangeable, due to the gudgen pin being bigger on the z22yh engine.
#15 vocky
Posted 28 June 2013 - 10:48 AM
I prefer the 11:1 pistons for some reason :mellow:
#16 siztenboots
Posted 28 June 2013 - 10:52 AM
I'd much prefer high compression turbo engine, with proper mapping , instead of some 80's throwback approach and daft AFR
#17 Claws
Claws
    Stage FA NA FTW!
  • 5,246 posts
Posted 28 June 2013 - 11:14 AM
#18 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 June 2013 - 11:36 AM
I understand.
Are there no third party high compression pistons for the standard rods out there?
#19 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 12:02 PM
You know, there is a good margin before the combustion chamber starts to be a dome. Then It's not difficult to calculate the CR by yourself
Currently we have (549.5 cm3 + Combustion chamber volume)/ combustion chamber volume =10
It means that 549.5 + CC = 10 CC ---->  549.5= 9CC ---->  CC= 61 cm3 (including the gasket)
If you skim 1mm of a round surface of 86 mm dia , it correspond to 5.8 cm3. so your new volume of CC is 55.2.
(549.5 +55.2) / 55.2 = 10.95
So the Doc was right
#20 2-20
2-20
  • 1,317 posts
Posted 28 June 2013 - 12:13 PM
About the Z22YH the CR is curiously advertised as 12:1 here and there
https://en.wikipedia...II_engine#Z22YH
And 11.3:1 for the 2.2 JTS used on Alfa-Romeo
Also tagged with one or more of these keywords: high compression, pistons, where to buy
