K16 Turbo Hybrid , Takes Standard Internals To 360/380Bhp
22 replies to this topic
#1 siztenboots
Posted 15 July 2013 - 09:51 AM
80mm maf , vxr blue injectors , probably the absolute limit now on conrods as torque is 520nm / 380lb.ft
turbo is not cheap and you could probably source the cold side yourself , can flow for 380bhp
#2 siztenboots
Posted 15 July 2013 - 10:00 AM
#3 jameso
jameso
  • 2,336 posts
Posted 15 July 2013 - 10:01 AM
Prolly worth doing internal there for piece of mind?
#4 siztenboots
Posted 15 July 2013 - 10:09 AM
this is a bolt on , uses existing water and oil feeds , standard exhuast downpipe
#5 T VXT
T VXT
  • 433 posts
Posted 15 July 2013 - 11:16 AM
[font="calibri;"] :o 380 on standard internals sounds a bit ambitious tbh, but you know a lot more than me![/font]
[font="calibri;"]The graph seem great, high power with torque kicking in as early as a stage 2![/font]
[font="calibri;"]Assume cc, 3inch exhaust and Dave Hardwick airbox or similar[/font]
Edited by T VXT, 15 July 2013 - 11:16 AM.
#6 jameso
jameso
  • 2,336 posts
Posted 15 July 2013 - 12:47 PM
Shame torque isn't a bit flatter :( Don't think that will destroy standard internals Steve?
Edited by jameso, 15 July 2013 - 12:47 PM.
#7 Asheey
Asheey
  • 550 posts
  • Interests:Cars, Bikes, Women and Beer.
Posted 15 July 2013 - 12:50 PM
Want!
#8 T VXT
T VXT
  • 433 posts
Posted 15 July 2013 - 03:03 PM
I'm sure a low boost map would flatten the torque and keep most of the top end, if that's what you want.
Go on then, what's the price of this turbo?
#9 techieboy
Posted 15 July 2013 - 03:06 PM
http://www.regelin-p...lader-zubehoer/
#10 T VXT
T VXT
  • 433 posts
Posted 15 July 2013 - 03:20 PM
:blink:
#11 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 15 July 2013 - 05:00 PM
If I was running this I would sure do it properly and get the internals done. Imagine spending all that hard earned cash and the engine goes. Looks good though.....so who on here will be the first?
#12 chris
chris
  • 524 posts
Posted 15 July 2013 - 06:01 PM
I have this turbo on my car, this is a log of a run in the fourth gear (M32 gearbox)
Edited by chris, 15 July 2013 - 06:01 PM.
#13 cs_
cs_
  • 213 posts
  • Interests:fast lightweight cars
    computers
    music
    home & family
Posted 15 July 2013 - 06:05 PM
There are several Speedsters here in Germany running this charger, all between 380 und 390PS (375...385BHP), including mine. You should NOT try this with standard internals, the engine cannot cope this power. But using forged pistons and cons you can have a lot of fun with this charger.
BUT
do not think this is a cheap one! You also have to do:
- exhaust (70mm at least)
- 80mm MAF
- complete optimized intake with large air filter
- an external *big* dump valve leading the air back to the intake, *not* out into the atmosphere(!!!), i.e. the Forge RS
- a better induction manifold like the Klasen SSR or the EDS pendant
- 630ccm Siemens Deka injectors
- high power fuel pump
- organic Sachs clutch for "normal" driving, sinter clutch from Mitsubishi Evo adapted for F23 if you drive Semi Slicks and have a launch control mounted (like me, just smoked the organic Sachs some weeks ago)
and lots of other optimizations.
Only the charger is not enough to get there. But if the whole peripherals are OK you will get a very smooth setup, high power with very nice drivability. You are f*cking fast and it still feels like a stage 2 or 3, only faster.
#14 cs_
cs_
  • 213 posts
    computers
    music
    home & family
Posted 15 July 2013 - 06:14 PM
This was my flywheel btw.:
Front side
Steel flywheel after thermal overload 1 (front side)
Back side
Steel flywheel after thermal overload 2 (back side)
Semis + Launch Control + Steel Flywheel + 380BHP did not work all together. :rolleyes:
#15 chris
chris
  • 524 posts
Posted 15 July 2013 - 06:54 PM
I doubt this preparation reach 380 BPH, more probably 340 - 350 bhp without special inlet camshaft ...
Have you got a log of a run of your car in particular with a MAF value  ?
:glare:
#16 cs_
cs_
  • 213 posts
    computers
    music
    home & family
Posted 15 July 2013 - 08:43 PM
It has Klasen cams and widened cylinder head. If you doubt, that's your problem.
Edited by cs_, 15 July 2013 - 08:44 PM.
#17 chris
chris
  • 524 posts
Posted 16 July 2013 - 04:09 AM
In fact this not a doubt, this is a conviction !
I have this turbocharger + all modification you have listed and even some other on my car ...
With a an air flow 270 g/s as I have recorded this does'nt correspond to the power you have announced ...
Have you got a log with MAF value or a map of this turbocharger ?
:dry:
#18 Duncan VXR
Duncan VXR
  • 5,283 posts
Posted 16 July 2013 - 05:49 AM
Considering the VXR injectors max at about 336bhp at 100% duty cycle its not a bolt on upgrade with out supporting mods - my previous experiance of the k06/k04 etc is not going to make that power - although the k04 on the tfsi lump will make 370+bhp not sure of internal / casting differences bettween the VXR one but on the VX220 they def dont make that :D
DG
#19 siztenboots
Posted 16 July 2013 - 07:29 AM
bits of this setup come from the porsche turbo , the problem with the k04 compressor manifold is that there is only so much you can machine off the inside to fit a larger profile wheel.
when people say k06, I think its the 2280 comp wheel, but the 2283 is the largest billet that BW do.
so if you break the price down to chra , wheels and housings , the bits are out there.
#20 siztenboots
Posted 16 July 2013 - 07:34 AM
regelin list the build on their site with those injectors , so I will believe them
http://www.regelin-p...65ps-520nm.html
