Edited by Jim_Cross, 10 August 2004 - 01:36 PM.
The Abs Letter - Another Response
Posted 10 August 2004 - 01:35 PM
Posted 10 August 2004 - 01:51 PM
Posted 10 August 2004 - 02:02 PM
Edited by benny_H, 10 August 2004 - 02:09 PM.
Posted 10 August 2004 - 02:06 PM
Posted 10 August 2004 - 02:14 PM
Now your just after an excuse to thrash around in fast cars all day, arnt you, go-on, admit it, we know you too well.If we're not happy with the results, then I think we would have to take a proactive approach, e.g. we set up a series of tests under conditions which we believe highlights the problem.
Quite how we could do this, without hiring somewhere like Millbrook I don't know. Perhaps we would need to get a magazine involved (any good magazine has regular access to places like Bedford or Millbrook)
Edited by mart356, 10 August 2004 - 02:16 PM.
Posted 10 August 2004 - 04:04 PM
Why isn't that a surpriseI've been told the conclusion states that they have found no safetz issue with the ABS system on the VX220/Speedster.
Keep it up mate
Posted 10 August 2004 - 04:16 PM
Posted 11 August 2004 - 07:47 AM
Posted 11 August 2004 - 09:10 AM
let's stand up and fight!!!
let's get the press involved!!!
Posted 11 August 2004 - 09:39 AM
Dissagree. the press will want more than "we think its an issue"let's get the press involved!!!
If we still believe it a genuine problem, we, as an owners club, should approach an independant organisation and ask them to run tests against how a benchmark car performs. There is a cost and we will have to cover that initially.
With these results(assuming conclusive), we can then approach Vauxhall again. Press is a last resort
Actually, i am sure we can run our own basic test initally! All we need it some tarmac, a GPS to measure speed, some gravel, a tape measure, a VX, a VXT, a VXR and some other cars!
Edited by cheeky_chops, 11 August 2004 - 09:41 AM.
Posted 11 August 2004 - 10:40 AM
Meanwhile, following an mention in another thread, I used Google to search on
abs 'ice-mode'
And variants. And lo - we're not the only people who've seen it - it's NOT car specific! Take a look but mentions go to a 350z, a Suzuki (Jimny - ugh!), scoobi's and some Jeeps. Basically if a wheel completely looses grip (so that's a patch of Ice/Gravel or Bouncing of the road or lifting on a severe manover) - ABS goes awol.
We are not alone
Paul
PS: http://auto.howstuff...-lock-brake.htm
has some interesting links at the end.
Posted 11 August 2004 - 02:09 PM
Posted 12 August 2004 - 06:21 AM
Interesting you should say that - I had a current model Seat Ibiza TDi for a (short) while and it had exactly the same problem as I think you guys are seeing with the VX; sometimes there just wasn't any braking available if the ABS had triggered.Look forward to reading the letter in full!
abs 'ice-mode'
We are not alone
Paul
The thing with the Beezer was that there was no patter through the pedal, it was just like the ABS released the pressure to unlock a wheel then 'forgot' to reapply it again. It was also evident that it was not capable of controlling one wheel alone as it cut the braking force entirely. One time it happened when it wasn't a frigtening situation I literally stood on the pedal and it just drifted gracefully to a halt. Very scary / potentially dangerous and not uncommon among drivers of the car according to the Seat boards.
I didn't every speak to the dealer about it but it was a contributer to my selling the car after 4 months.
Posted 12 August 2004 - 07:01 AM
I have had lots of problems with the ABS on my Ibiza Cupra (virtually from new). It's got to the stage where it even comes on without pressing the brake sometimes (at least the motor/pump - or whatever it is that causes the brakes to catch/release - comes on). No brake activation - just the pump.The thing with the Beezer was that there was no patter through the pedal, it was just like the ABS released the pressure to unlock a wheel then 'forgot' to reapply it again. It was also evident that it was not capable of controlling one wheel alone as it cut the braking force entirely. One time it happened when it wasn't a frigtening situation I literally stood on the pedal and it just drifted gracefully to a halt. Very scary / potentially dangerous and not uncommon among drivers of the car according to the Seat boards.
I gather it's something to do with the sensor(s) being out of alignment. Only takes a very slight mis-alignment to make it trigger at strange moments.
Nothing dangerous (yet) in nearly 5 years of ownership, but none of the dealers it has been to (at least 4) seem to be able, or willing, to do anything about it.
Posted 12 August 2004 - 07:06 AM
Posted 12 August 2004 - 07:15 AM
Posted 12 August 2004 - 07:26 AM
Posted 12 August 2004 - 07:47 AM
Posted 12 August 2004 - 06:39 PM
