Best Air Filter Options For Sc 250-350Bhp
Posted 07 August 2013 - 07:59 PM
Posted 07 August 2013 - 08:05 PM
Posted 07 August 2013 - 08:08 PM
But then I'd always have an excuse for being quicker than you! At least if we're both SC its a tad more fair.Leave it add NA, done...
Posted 07 August 2013 - 08:15 PM
Posted 07 August 2013 - 08:16 PM
Edited by MrSimba, 07 August 2013 - 08:18 PM.
Posted 07 August 2013 - 08:20 PM
This does sound like the best option for engine safety and flow. Price is a little eye watering but I'm sure something can be done. Even if I made my own take on the box flow. Biscuit tins riveted together like Lee's build for instance.I know its not an SC but with the std filter and a 'Dave Hardwick' airbox on the EFi dyno there was absolutly NO difference between having no filter in the airbox, just an 'open' intake to the engine, and the std filter with Dave's deretricted airbox, and that was at over 400bhp! Derestrict the airbox & stay standard for best filtration!
Posted 07 August 2013 - 08:22 PM
You could easily just make your own from 2 OEM filters. That way you ensure that you are getting high particle filtration, it will cost peanuts to make and lastly you know it will flow well enough. Hell you could even make a 3 panel filter !
One thing I can say though (through personal experience and listening to a couple of other 360 BHP owner cars) that minimising pressure loss over the air filter is really fundamental to getting good power. In my case when I built my own filter + larger bore intake pipes I epic amounts more power (around 45 BHP at a guess).
good luck either way, shame I never got a psx ride when it was NA (my fault for not re-finding you at the National)!
Edited by Nev, 07 August 2013 - 08:24 PM.
Posted 07 August 2013 - 08:23 PM
The standard paper air filter is good for over 500bhp. It also filters the air much better than these aftermarket ones.
There's no reason to change, in fact people that do are generally reducing the life of their engine due to poorer filtration.
Posted 07 August 2013 - 08:28 PM
Limited space in the ear for a SC conversion but its something not been tried yet. Hmmmmm, where's joe and his dremmal?You could easily just make your own from 2 OEM filters. That way you ensure that you are getting high particle filtration, it will cost peanuts to make and lastly you know it will flow well enough. Hell you could even make a 3 panel filter ! One thing I can say though (through personal experience and listening to a couple of other 360 BHP owner cars) that minimising pressure loss over the air filter is really fundamental to getting good power. In my case when I built my own filter + larger bore intake pipes I epic amounts more power (around 45 BHP at a guess). good luck either way, shame I never got a psx ride when it was NA (my fault for not re-finding you at the National)!
Posted 07 August 2013 - 08:52 PM
Perhaps when you have brakes and suspension to match your engine (banter) ill allow you to take me for a spin!?
Admittedly I only have RC6 pads and OEM callipers, but what is it that you think is wrong with my suspension?
Posted 07 August 2013 - 09:00 PM
Posted 07 August 2013 - 09:49 PM
if you can find the space, then surly an air box from a v8 or some other 400 bhp standard car would be cheap on ebay?
Posted 07 August 2013 - 09:50 PM
Have you seen what area we have to work with!if you can find the space, then surly an air box from a v8 or some other 400 bhp standard car would be cheap on ebay?
Posted 07 August 2013 - 09:56 PM
yes but when I have the car in bits the space is always bigger then I remember..
Maybe when I'm in the arch liner this weekend I will get the tape measure out..
Posted 07 August 2013 - 09:57 PM
yeah there's a fair amount of room actually when you think about it
Posted 07 August 2013 - 10:00 PM
Posted 07 August 2013 - 10:06 PM
So I need to spend £2k on a coupe back for me to access more space?Lee has freed up a load of space by fitting the coupe back (and cake tins)
Posted 07 August 2013 - 10:13 PM
Errrrr....yesSo I need to spend £2k on a coupe back for me to access more space?Lee has freed up a load of space by fitting the coupe back (and cake tins)
Edited by Sticky, 07 August 2013 - 10:14 PM.
Posted 07 August 2013 - 10:18 PM
Remember, the Harrop is massively quieter than an overdriven M62. So you might be trying to solve a problem that doesn't really exist.I don't mind the noise of the SC but when I eventually go harrop running over 350bhp its going to become an issue for some tracks. So I don't mind having an inclosed unit as long as it can flow the air needed.
I run the Pipercross VM-7000 with the 100mm intake option and 80mm exit to the throttle body. It's allegedly good for 400bhp and it's definitely knocked a few db's off at the high pitched end of the SC noise and generally feels a little more muted than the sh!tty great big Cosworth cone filter and whatever it was Courtenay's fitted before that.
I've tried to fit a few. The problem with air boxes from powerful NA V8's is that they're either meant to fit in the V or above the V or they have stupidly shaped flat intakes and ducting to sneak a bit of air from a slot behind a grill etc.
Best bet may still be to use the NA airbox as Exmantaa did on somebodys conversion. Winstar reckoned with a few of the normal mods to the airbox trumpet etc, that it was more than man enough for the job and was better designed than the turdo's airbox (which I also tried). I'd have it in the car now, if the ECU wasn't located where it is, though Exmantaa did manage to squeeze it in.
