Engine Dies To Idle And Wont Rev
19 replies to this topic
#1 kevin o
kevin o
  • 21 posts
Posted 16 August 2013 - 06:02 AM
managment liight comes on and car dies to idle will not rev turn off engine and re start it runs alright but light stays on runs for a while then dies again any ideas cheers boys
#2 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 16 August 2013 - 06:04 AM
Water in coil pack at a guess? Been raining your way?
#3 LY_Scott
LY_Scott
    Formerly LY055SCO
  • 9,221 posts
Posted 16 August 2013 - 06:28 AM
:yeahthat:
#4 rob999
rob999
    Cat in a Hat
  • 12,795 posts
Loom of do doOoOoOommmmmmm
#5 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 16 August 2013 - 06:48 AM
If its not got wet try unplugging the maf and see if it any better NA or turdo ?
#6 Pidgeon
Pidgeon
  • 5,254 posts
Posted 16 August 2013 - 06:50 AM
My money's on throttle pedal, but knowledge of which car we're talking about would help.
#7 Nev
Posted 16 August 2013 - 07:07 AM
Ummm, first thing to do is read the error codes out of the ECU rather than guessing... that's why the little light comes on. You can buy a cheap ODB2 code reader off eBay if you don't have one already.
#8 FLD
Posted 16 August 2013 - 07:09 AM
:yeahthat:
#9 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 August 2013 - 07:13 AM
When did it start doing it? If it was after a rain storm then as above
#10 kevin o
kevin o
  • 21 posts
Posted 16 August 2013 - 07:43 AM
thnaks for your replies it is a NA model 2003 just borrowed a code reader so i will check that out later today
#11 Goosenka
Goosenka
  • 12,716 posts
Posted 16 August 2013 - 07:44 AM
While your waiting take the coil pack off and see if it is wet.
#12 kevin o
kevin o
  • 21 posts
Posted 16 August 2013 - 09:05 AM
just done a fault test code p1271 throttle body cencor came took  it off and sprayed wd40 on it going to give a go but do you normally have success with doing this
#13 smiley
Posted 16 August 2013 - 09:32 AM
1271 is loom of doom.
The 2 black and blue connectors under the header tank need a check, and some contact spray.
#14 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 16 August 2013 - 06:27 PM
don't use WD40 to clean electrical connectors.. Its not what its for and within 40 days you may have the same problem back. use electrical contact cleaner and clean the connections as above
its cheap from halfords
Edited by Stuwy has gone fishing, 16 August 2013 - 06:28 PM.
#15 kevin o
kevin o
  • 21 posts
Posted 21 August 2013 - 05:07 PM
car seems alright now blew all connectors out with a air line to dry them out give them a clean used it since saturday with no problems about 300 miles so fingers crossed :happy:  :happy:
#16 jameso
jameso
  • 2,336 posts
Posted 22 August 2013 - 02:07 PM
Frequency of LoD posts is really high these days!
#17 FLD
Posted 22 August 2013 - 02:09 PM
Cars are getting old.  Its interesting seeing what gets posted these days compared with a few years ago.  Suspension refreshes are getting common too.
#18 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 30 March 2014 - 12:12 AM
Damn had this tonight. Pain in the ass on the A13
#19 Nev
Posted 30 March 2014 - 08:47 AM
I think garaging the cars helps with this sort of thing a good deal.
#20 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 30 March 2014 - 09:16 AM
yes that may be, but I don't have the space for a garage. I'm planning on a carport build in the summer. To be fair this is the first sort of issue I have had like this. Its more likely caused by me spilling water as the engine bay get covered with mats when not in use.
I need to work out if its the pedal sensor itself as I noticed that the loom was getting caught on the brake return spring, or the blue and black connectors..
Its a job for another day
