Vx220 Fan Replacement Part? Universal Fan?
6 replies to this topic
#1 Bolt666
Bolt666
  • 105 posts
Posted 19 August 2013 - 08:55 AM
Hi All!!
My cooling fan is dead and I am now sourcing a replacement fan - will a universal fan do the job?
I note that these can be picked up for £20 (instead of £50 from eliseparts) and would be intending to mount two fans across the radiator.
If any one has tried one it would be good to hear any feedback on them!
#2 siztenboots
Posted 19 August 2013 - 09:03 AM
its not the cost of the fan , but the labour to remove the front clam and all the rads. if you do this replace all the rusty fittings with stainless
#3 Bolt666
Bolt666
  • 105 posts
Posted 19 August 2013 - 09:16 AM
I have already removed the clam (what a mission!) and the rad, tested the fan on a battery and found it to be dead entirely! Its just a case of new fan now and re-assemble but a lot of copper grease will be used with new bolts for this!
#4 Arno
Arno
  • 1,238 posts
Posted 19 August 2013 - 11:44 AM
Hi All!!
Yup. Fairly basic SPAL units that should be availabl from more sources.
Make sure though to get fans that:
- Are sealed well (rain pools onto them)
- Move air the correct direction
- Have separate fan blades like the OEM fan
The last point is something I found myself with some of the uprated SPAL fans. These often have a retaining ring around the fan blades (and often more of a curve to the blades), but in the VX/Elise installation with the fans under the rad this seems to trap dirt/leaves/junk between the fan edge/ring and the radiator surface. In many cases this leads to the fan running heavy/difficultly and failing much more quickly than the OEM design.
2 fans fit fine side by side, just get some extra brackets. Depending on your rad you may need to drill some extra mounting holes.
It's advisable though to 'slave' the second fan from the first one via it's own dedicated relay/fuse and feed from the battery as they do pull quite some power (esp.on startup) and the normal fuse and wiring may not enjoy running 2 fans at the same time.
#5 simonlpearce
simonlpearce
  • 933 posts
Posted 19 August 2013 - 12:07 PM
The cheaper £20 or so universal fans are a bit hit and miss in my experience. I had one that lasted over a year, then i sold the car and it got removed. I had another that lasted a couple of months before dying.
You want the fans to be independent of each other if you are getting 2, so if the fuse blows on one the other will continue to cool.
#6 Andrew aka Stuwy
Andrew aka Stuwy
    Made In England
  • 8,731 posts
Posted 19 August 2013 - 02:17 PM
i has a fan and rad working removed from a 44k mile car
£20 and its yours but your a bit far away lol
#7 Bolt666
Bolt666
  • 105 posts
Posted 19 August 2013 - 03:20 PM
Thanks for the all the advisel!
Shame you are so far away! I would be tempted though as if you mean £20 for rad and fan seems like a bargain to me!
