Stack Warning Lights Meaning
15 replies to this topic
#1 sguesty1987
sguesty1987
  • 171 posts
  • Interests:West Bromwich Albion, F1, Motorsport, My Silver Pocket Rocket
Posted 21 August 2013 - 11:18 AM
Hi all. What's the meaning of the bottom right light on the stack dash? If it stays on does this indicate an EML code? I can believe it if so as I've just changed my backbox from VSE to turbo std (well, BoT did).
#2 iain3915
iain3915
  • 269 posts
Posted 21 August 2013 - 11:27 AM
Yep - that's the engine management light highlighting that there is a fault code.
My guess is it'll be to do with lambda sensors if you have just changed the exhaust.
#3 slindborg
Posted 21 August 2013 - 12:01 PM
odds on the post cat lambda sensor was plugged into the wrong harness connector (two in the same area which both fit :lol: )
#4 christhegasman
christhegasman
  • 5,316 posts
  • Interests:cars
    motorsport especially BTCC
    rugby
    eating out
    keeping fit
Posted 21 August 2013 - 12:11 PM
Did the same on my NA bottom left hand side as you look from the back l
#5 sguesty1987
sguesty1987
  • 171 posts
Posted 21 August 2013 - 12:12 PM
It wasnt unplugged but I guess it has been disturbed. Or could it be breathing differently means its returning a different value which it doesn't like?
#6 smiley
Posted 21 August 2013 - 12:52 PM
Yes, the wiring can get brittle over the years, and break when moved.
Get a code reader out, get vauxhall to read it for you, or find someone local with a reader.
From the code we can tell you what wire is broken.
Some wiring can be fixed, but if broker near the lambda itself, you may need to buy a new one.
#7 slindborg
Posted 21 August 2013 - 01:09 PM
That or they coated the sensor in WD40 prior to removal and thats peeeenarsed the sensor.
#8 sguesty1987
sguesty1987
  • 171 posts
Posted 21 August 2013 - 09:50 PM
Cheers Slindborg. Will get it read. Ran with it at Brands this eve as is and all was ok.... Guess it was just running open loop.
#9 Roastie ITR
Roastie ITR
  • 365 posts
Posted 21 August 2013 - 09:53 PM
Assume you must have the silver VX that was up on the ramp when I dropped my red VX off at BOT this morning?
#10 sguesty1987
sguesty1987
  • 171 posts
Posted 22 August 2013 - 08:07 AM
That was me yep! What was yours in for? Yours was looking nice...
#11 LazyDonkey
LazyDonkey
    Lotus imposter
  • 7,748 posts
Posted 22 August 2013 - 08:17 AM
Is now a good time to mention that the turbots actually had fake stacks ;)
#12 sguesty1987
sguesty1987
  • 171 posts
Posted 22 August 2013 - 09:25 AM
Mines an NA :)
#13 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 22 August 2013 - 10:31 AM
Why is everyone getting turdo exhausts?
#14 Roastie ITR
Roastie ITR
  • 365 posts
Posted 22 August 2013 - 12:38 PM
Your's too mate. Just it's annual service and new steering UJ's being fitted.
#15 sguesty1987
sguesty1987
  • 171 posts
Posted 22 August 2013 - 01:46 PM
Mine was shamefully dirty. Had to wash it before the trackday. I do like the rab red.
#16 sguesty1987
sguesty1987
  • 171 posts
Posted 22 August 2013 - 01:47 PM
For me it was just future proofing in case one day I can SC....
