Hello everyone!
Regards from Spain
Posted 12 September 2013 - 03:30 PM
Hello everyone!
Regards from Spain
Posted 12 September 2013 - 04:29 PM
I am going to Tenerife in October. I will look out for you
Posted 12 September 2013 - 10:23 PM
Mine has done this for years! Perhaps tightening the U joint will help?
Posted 12 September 2013 - 11:02 PM
Posted 12 September 2013 - 11:06 PM
Posted 13 September 2013 - 09:28 AM
Grab hold of your front right hand wheel, move it side to side. If you look inside the wheel arch you should be able to see the steering rack at about the 10 o'clock position. Watch and listen as this could be the source of your knocking noise.
Edited by peteslag, 13 September 2013 - 09:28 AM.
Posted 13 September 2013 - 12:05 PM
This evening I will look it, thank Peteslag
I forgot to comment...the last year I change the tracks rods end but I don´t know if it is the problem
Posted 13 September 2013 - 12:28 PM
Not likely. See if your steering rack has any play, it is as good as any a place to start.
Posted 09 March 2014 - 02:50 PM
Hi mate, no I think that my steering doesn´t has play, works perfect, but with noise again
It is very disappointing, Drive the car for fun and listen to that infernal noise
Posted 09 March 2014 - 07:46 PM
Hi Buddy,
There are 4 screws holding your steering rack onto the chassis. You can find these screws in the cabin, 2 just behind the pedals and the other 2 are over your footrest (different sizes, maybe 13 and 17...) Try to loosen them up a little bit (don´t need to remove the screws) and them re-tighten them fully.
Posted 10 March 2014 - 09:08 AM
Thank
I´ll try it
