Hid Fitting / Black Na Lights / Light De-Mist / De-Badging Guide
16 replies to this topic
#1 tbs30stm
tbs30stm
  • 338 posts
  • Interests:Cars, my band, learning Russian, guitars, music production and more cars
Posted 19 September 2013 - 09:07 PM
I am probably posting this in the wrong section (please tell me if it is) but for some reason I can't start new topics in the 'Guides and Tutorials' section of the forum, so here goes.
I very recently bought my Silver NA and already had a few changes lined up in my head which are listed below:
- I wanted HID's
- The front/rear lights were leaking water and misting up
- As I was de-misting the lights anyway I thought I would spray them matte black as I prefer the look
- I didn't like the look of the dinner plate sized badge on the back so that was coming off.
Rear badge removal
This is very easy to do as you can all imagine. I used some WD-40, warm water, a sponge and a flat plastic kitchen thing that i've never used.
1. Spray WD-40 on the badge and leave for 10 minutes
2. Using warm water and a sponge, soak the badge whilst using a flat edged bit of plastic (or whatever else you can find) to life the edge of the badge up
3. Work your way around the badge whilst using the warm water and it will come off very easily.
4. Then I used Autoglym Tar Remover to get the remaining adhesive off the paint work.
This is the result
As you can see, it's quite simple!
#2 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 20 September 2013 - 04:40 PM
As long as it wasn't like my rear badge that someone superglued!
#3 tbs30stm
tbs30stm
  • 338 posts
Posted 20 September 2013 - 05:06 PM
It wasn't superglued luckily! I will post the rest of the guide when I get home, I think the site crashed last night when I was in the middle of posting it....
#4 tbs30stm
tbs30stm
  • 338 posts
Posted 20 September 2013 - 07:12 PM
Front and Rear light cluster removal and de-mist
Rear
1. Remove the 4x 8mm nuts from inside the boot
2. Unclip the power connection
3. Slowly pull the rear light cluster out
4. Repeat for the other side
Front
1. Remove the 13mm nut
3. Slowly pull the light cluster out
De-mist
This isn't as east as it sounds as you have to remove the covers off all the light clusters.
1. Using a hair dryer (or similar), blow hot air (without melting anything) around small areas first
2. Use a stanley knife and carefully cut through the heated sealant
3. Repeat steps 1 and 2 until the cover is ready to be lifted off. Do this carefully so you don't crack the cover.
4. Repeat all steps on each light cluster to remove the cover.
5. Clean the inside of the light clusters and remove and rubbish that's inside.
6. Dry with a hair dryer
Next is priming and painting the clusters.
#5 tbs30stm
tbs30stm
  • 338 posts
Posted 20 September 2013 - 09:29 PM
Painting the light clusters black
1. Make sure the surface of the light cluster is clear of rubbish/dust/mold/things unknown to science
2. Put masking tape over the lenses
3. Spray the cluster with grey primer and wait for it to dry
4. Once dried, decide if it needs another coat/touching up
5. Spray the black over the primer and repeat step 4 if you need to
6. After the paint is dry and masking tape removed, start sealing the covers back onto the light clusters
7. Leave the adhesive/sealant to dry for a while before putting the lights back on the car and job done!
DO NOT DO WHAT I DID! MAKE SURE YOU USE BLACK SEALANT NOT WHITE!
*insert abuse here*
Amateur mistake, it doesn't show up that much but you can see the white sealant slightly on the rear lights.
Before
After
Next is the HID kit installation
#6 tbs30stm
tbs30stm
  • 338 posts
Posted 20 September 2013 - 10:22 PM
HID installation guide
The kit I bought was from HIDS4U and cost me £80, I decided to get this kit instead of an Ebay one because it comes with a 2 year warranty and they have very good reviews and I must say, the service was very good and very fast!
Here is the link to the VX kit I purchased -
http://www.hids4u.co...ersion-kit.html
1. Remove the headlights (see images above)
2. Remove the old bulb
3. Find somewhere to mount the ballast and clean the area prior to mounting it.
4. Start connecting the kit together
5. Fit the new bulb (test if you need to by connecting power to the light unit)
6. Mount the ballast
7. Tidy up the wires if you need to and connect the power
8. Put the headlight back in, repeat for the other side and enjoy!
HID vs Standard
Night time test
I hope some of you guys find these guides useful! If I can do it, i'm sure anyone can as i'm absolutely useless at anything DIY!
Any feedback is appreciated
Cheers,
Rob
#7 Strugs
Strugs
    World's #1 cheese fan
  • 3,008 posts
Posted 20 September 2013 - 10:35 PM
Really nice clear "how-to's" - you've gone to some effort there, good stuff.. chinky chinky
#8 tbs30stm
tbs30stm
  • 338 posts
Posted 20 September 2013 - 10:55 PM
Thanks   thumbsup
#9 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 24 September 2013 - 02:44 PM
Good guides :)
Using dental floss like a saw works well to remove the rear badge as well if you don't have "a flat plastic kitchen thing" :lol:
Does somebody want to move this to the correct section #organisation :P
#10 xiodene
xiodene
  • 330 posts
Posted 28 October 2013 - 03:13 PM
Very useful, I will use this when fitting my HID kit!
#11 Ormes
Ormes
  • 4,612 posts
Posted 06 November 2013 - 06:39 AM
Nice guides, thanks for the contribution thumbsup
#12 Calcium09
Calcium09
  • 73 posts
Posted 06 November 2013 - 10:57 AM
Did u have to get a bulb holder for the hid?
#13 tbs30stm
tbs30stm
  • 338 posts
Posted 06 November 2013 - 11:50 AM
Thanks!
#14 tbs30stm
tbs30stm
  • 338 posts
Posted 06 November 2013 - 11:51 AM
Nope, they just went straight in
#15 myles
myles
    Sausagefest
  • 2,093 posts
Posted 06 November 2013 - 12:51 PM
My front lights are now getting a little misty. This guide will help me no end, thanks!
(or keep an eye out for 'Front Lights Wanted- I destroyed my last set' post!)
#16 aKra
aKra
  • 109 posts
Posted 06 November 2013 - 01:36 PM
Could you tell me why you made a little incision in the front headlight rubber? Why not a hole and fill it with the rubber plastic provided? Otherwise they will keep being misty ;)
And, how did you fastened the Xenon starters? 3M sticky icky?
Edited by aKra, 06 November 2013 - 01:36 PM.
#17 p4cks
p4cks
    Newbie abuser
  • 6,430 posts
Posted 06 November 2013 - 04:34 PM
Some very good guides there. I'm very much looking forward to having idiots quote them in their replies.
