Na Gearbox Modifications
na gearbox modifications
12 replies to this topic
#1 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 September 2013 - 07:41 PM
The standard gearbox - Are there any mods worth doing?
#2 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 28 September 2013 - 08:15 PM
Put a gearbox breather on if you tend to drive the car in spirit once i a while.
#3 Defcon5
Defcon5
  • 480 posts
  • Interests:Detailing, Motor Racing
Posted 28 September 2013 - 08:58 PM
Pros of the gearbox breather? May add it to my winter mods list
#4 smiley
smiley
    Thetan level 15
  • 10,427 posts
Posted 28 September 2013 - 09:08 PM
When driving in spirit (usually on track), the gearbox oil heats up, and can squirt out via the breather nipple.
As that is near the left rear wheel , it's potentially dangerous on track.
It also creates a bit of a mess in the engine compartment.
The mod gives the stock breather nipple some extra room.
#5 fezzasus
fezzasus
  • 7,689 posts
Posted 28 September 2013 - 09:38 PM
Oil cooler. Barb on the level port, barb on the fill port, circulated through a cooler (obviously) but only if heat management becomes an issue. Alternative is to use a thicker oil so it thins less.
#6 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 28 September 2013 - 11:28 PM
Anything in relation to gearing?  Change ratios? Can I add an extra gear? :D Two speed reverse anybody? :P
#7 davemate
davemate
    Harrop!!!
  • 3,228 posts
  • Interests:Provoking Badgers
Posted 28 September 2013 - 11:35 PM
You could put in a lower final drive ratio. But for the cost you may as well swap in a zafira box for the same final product. Good for track, but for road use I wouldn't bother as the noise would be annoying in my opinion.
#8 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 29 September 2013 - 08:17 AM
Changing ratios and final drives is an expensive business :( I wouldn't agree that a Zaf box would be too noisy though. Could get an LSD?
#9 mark moyz
mark moyz
  • 643 posts
  • Interests:Redundancy demotions pay cuts 0 hours contracts employment shaftings
Posted 29 September 2013 - 09:03 AM
I have the 4.17 final drive sat at home and I have been quoted a very reluctant £500 to fit it at Phoenix motorsport as his words were its a PITA to do.
#10 davemate
davemate
    Harrop!!!
  • 3,228 posts
Posted 29 September 2013 - 11:00 AM
The car already sits high in the rev range on the motorway, increasing this would be irritating in my car.
#11 Sticky
Sticky
    iTB lover
  • 3,462 posts
Posted 29 September 2013 - 11:03 AM
You should try a 4.6FD, now that is irritating!
#12 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 30 September 2013 - 08:37 AM
For LSD I'm assuming Quaife are king of the road
http://quaife.co.uk/...oducts/qdf17b-2
#13 slindborg
slindborg
    The Bishop of Stortford
  • 22,602 posts
Posted 30 September 2013 - 09:25 AM
NO!!!!! (well ok may have them but that doesnt mean its the right answer.
Plate diff and do it right if you want to add an LSD, many deem it pointless/not worth the cash.
Also tagged with one or more of these keywords: na, gearbox, modifications
