Toe Link Kits
34 replies to this topic
#1 Guesty88
Guesty88
  • 107 posts
Posted 09 October 2013 - 01:03 PM
I'm getting some new dampers soon, and whilst it's being done I thought it might be worth getting one of the uprated toe link kits from VX220 Parts or Elise Shop (I'm pretty sure the originals are still on the car, and it's done 60k so they're due to be replaced anyway). I don't have grippy tyres yet but I would've thought it's an almost inevitable mod at some point, with Bridgestone fronts becoming something of a rarity.
Does anyone have any strong feelings about which toe link kit is the better?
I noticed VX220 Parts has two options for the outboard joint, parallel or tapered, and recommends you check which one is on your car. From what I can gather though, the parallel joints are fitted to all models from 2003 onwards with the tapered joints being used prior. Is that a hard and fast rule? My car was built at the back end of 2001 so should in theory have a tapered joint. Does the lack of such an option for Elise Shop's kit mean it is more difficult to fit? Not that it will be me fitting it, but I would rather something that is a direct swap for the original part.
Any advice gratefully received!
#2 Bumblebee
Bumblebee
  • 7,592 posts
Posted 09 October 2013 - 01:06 PM
There's also the spitfire toe link kit as well. I've got there kit and brace bar.
Edited by Bumblebee, 09 October 2013 - 01:11 PM.
#3 Guesty88
Guesty88
  • 107 posts
Posted 09 October 2013 - 01:23 PM
This may be a stupid question, but where do you get Spitfire stuff from? I'd had a search in Google but it just turned up threads on here.
#4 techieboy
Posted 09 October 2013 - 01:25 PM
Spitfire kit is/was available from Elise-Shop, it's there more expensive version.
The cheaper kit from Elise-Shop comes with parts suitable for both tapered and parallel options.
#5 Captain Vimes
Captain Vimes
  • 2,755 posts
Posted 09 October 2013 - 01:27 PM
Elise shop kit includes spacers for both types of joint. As I didn't know exactly what I needediI went for the elise shop version.
#6 D3YMO
D3YMO
    Scammer
  • 1,554 posts
  • Interests:Cars, Gym, Basketball, Football, LFC, Usual Stuff...
Ollys kit from Pheonix is about £240 + £40 for the brace bar...+£100 fitting and set up after
#7 dw1
dw1
  • 3,043 posts
Posted 09 October 2013 - 01:54 PM
You've got a number of options, all seem decent. I have the spitfire and the spitfire brace bar which are designed to work together i.e. the spitfire brace bar only works with spitfire toe links. I have both and am a big fan of the brace bar. With brace bars you need to be careful they fit under the exhaust. What exhaust do you have?
#8 Bumblebee
Bumblebee
  • 7,592 posts
Posted 09 October 2013 - 02:04 PM
I'm due to have mine (brace bar) fitted by cornering force and I believe its been altered slightly so it fits with an aftermarket exhaust....well this is the case with mine :)
#9 fezzasus
Posted 09 October 2013 - 02:05 PM
Elise shop is the cheapest, comes with all the part variations and is good quality.
#10 JamesC
JamesC
  • 991 posts
  • Interests:Cars, Beer, Diving, not necessarily in that order....
Posted 09 October 2013 - 02:14 PM
Another vote for the Elise Shop kit from me, nicely made and good value.
#11 siztenboots
Posted 09 October 2013 - 02:59 PM
very pleased with my elise-shop kit , the convenience of both types of fitting included was a big plus
#12 smiley
Posted 09 October 2013 - 04:19 PM
You allready on 3"?
#13 Bumblebee
Bumblebee
  • 7,592 posts
Posted 09 October 2013 - 04:37 PM
Milltek but will be going for the 3" exhaust and have been told it will still fit :)
#14 Arno
Arno
  • 1,238 posts
Posted 10 October 2013 - 06:28 AM
Other way around..
Pre-2003 cars have parallel joints.
Later cars (and virtually all tubby's) have tapered joints.
However... If any repairs have been done in the past or Lotus found some bits in a parts bin it may have different ones installed. Some reports of cars with both types on the same car as well!
If yours is a 2001 and has not had any repairs in this area then is very linkely that it's the parallel connection type in the upright.
#15 CocoPops
CocoPops
  • 17,182 posts
Posted 10 October 2013 - 06:51 AM
Another Elise Shop vote here.
#16 Pidgeon
Pidgeon
  • 5,254 posts
Posted 10 October 2013 - 07:34 AM
Hmmm, Yvo sent a bag of bits to cure the play in mine, had play in three of the four ends.  Another 'improvement' I wished I had never bothered with.
#17 siztenboots
Posted 10 October 2013 - 07:38 AM
which kit , the standard or the 'motorsport' spitfire one
#18 Pidgeon
Pidgeon
  • 5,254 posts
Posted 10 October 2013 - 09:06 AM
Standard.Play in the bolt and shim arrangement onto the hub end and in at least one of the Rose joints
#19 ghand
ghand
    Drunken lampposts only
  • 9,215 posts
    Oh and more whisky
I think it was the uprated toe link bar that bent the chassis on the crashed car I looked at. So you hit the curb or something whith the rear wheel the super strong link set up will not snap, it twists the mounting point and another scrap car. Or am I talking bollocks as usual ? :lol: it just looked like that to a non expert.
#20 siztenboots
Posted 10 October 2013 - 09:17 AM
just the rear subframe , not the chassis
