Plastic Door Card Inserts
26 replies to this topic
#1 coldel
coldel
  • 1,183 posts
Posted 15 October 2013 - 03:48 PM
Can these be removed without the need to remove all the surrounding padding, the pieces I mean are the two pieces in each door which are held on with the window winder and the door opening handle.
Or is it simpler just to take the whole lot off? Ideally I want to pop them off, get them tidied up, put them back on again.
#2 Goosenka
Goosenka
    Jeep Driving jolly nice chap
  • 12,716 posts
Posted 15 October 2013 - 03:52 PM
Whole lot off.
#3 coldel
coldel
  • 1,183 posts
Posted 15 October 2013 - 03:54 PM
Thought so, ta
#4 techieboy
Posted 15 October 2013 - 04:07 PM
You have to remove the two silver plastic trims to get the main door card off. So, yes, they come off separately and no need to disturb the vinyl covered door card.
#5 Paulus H
Paulus H
  • 2,063 posts
Posted 15 October 2013 - 07:09 PM
Agree with Techi. You only need to remove the outer trim if you need to remove the door release handles.
I refitted the large silver trim using velcro.
KInd regards, Paul
#6 Goosenka
Goosenka
  • 12,716 posts
Posted 15 October 2013 - 07:11 PM
I agree with Techie as well. He's the best :thumbsup:
#7 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 16 October 2013 - 10:06 PM
undo the four bolts for the window winder then the single bolt for the winder rear piece, pull off the door card that is held on by fir tree fasteners or Velcro if someone's already changed it, then unscrew the 2 scrivets for the door triangle and carefully remove the triangular card around the door release. The triangle part has a l-shaped tab at its front edge that hooks around the door trim (if it hasn't already snapped off). Existing silver paint might react with new paint and might need to be stripped. It's black plastic underneath.
#8 coldel
coldel
  • 1,183 posts
Posted 17 October 2013 - 08:01 AM
Super thanks chappers - still umming and urring on whether to put more red carbon on it or just spray it black or silver...have sprayed plenty of stuff quite happy rubbing away paint layers  :happy:
#9 chappers2000
chappers2000
  • 489 posts
Posted 17 October 2013 - 11:53 AM
Originally silver carbon wrapped my door cards and the triangle and left the bit inside the triangle black plastic after taking the silver paint off it with some white spirit and a finger nail. Looked really good but then painted it as the tight corners on the similarly wrapped dash plates kept eventually lifting and couldn't face having to keep re-wrapping it. Now it's all grey enamel painted.
#10 Asheey
Asheey
  • 550 posts
  • Interests:Cars, Bikes, Women and Beer.
Posted 17 October 2013 - 02:39 PM
Mine look like this.
#11 D3YMO
D3YMO
    Scammer
  • 1,554 posts
  • Interests:Cars, Gym, Basketball, Football, LFC, Usual Stuff...
Posted 17 October 2013 - 02:58 PM
are these dipped or wrapped?
#12 coldel
coldel
  • 1,183 posts
Posted 17 October 2013 - 03:06 PM
Thats dipped I would have thought? You wouldnt get the vinyl to wrap that well? This is how my dash plates look using the dip process, thinking of the same for the doors
#13 Wreelybro
Wreelybro
  • 1,641 posts
    360 Gaming 10-Pin Bowling.
Posted 17 October 2013 - 06:34 PM
Looks good
#14 nicollow
nicollow
  • 3,801 posts
Posted 17 October 2013 - 07:26 PM
That looks pretty sweet actually....   ;)
#15 Sweet_tooth
Sweet_tooth
  • 342 posts
Posted 18 October 2013 - 05:53 AM
When you say dipped, what with haha, and how much?
#16 Asheey
Asheey
  • 550 posts
Posted 18 October 2013 - 07:43 AM
#17 pete-r
pete-r
  • 2,771 posts
Posted 18 October 2013 - 08:24 AM
I've wrapped mine. It can be done if you have the patience.
#18 coldel
coldel
  • 1,183 posts
Posted 18 October 2013 - 08:58 AM
Good work, must have been 3m or hexis vinyl? Can only just see the joins, nicely hidden! I do use vinyl on simple flat surfaces but hydro graphics give a much better finished, although more expensive. To do my two dashplates was £55.
#19 pete-r
pete-r
  • 2,771 posts
Posted 18 October 2013 - 10:52 AM
I have a supplier friend, it's a 'not available in the shops' arrangement lol I am available for commission ;)
#20 coldel
coldel
  • 1,183 posts
Posted 18 October 2013 - 12:37 PM
The problem with vinyl and complex shapes is the amount of stretching you have to do, so the pattern gets really distorted.
