Replacement Wheels Vx220 Turbo
30 replies to this topic
#1 Aussievx220
Aussievx220
  • 33 posts
Posted 04 November 2013 - 06:36 AM
Hi all, I have been looking at replacing my tyres and found out that the front tyres are 175/55R17. Australia doesn't stock these tyres at all! I was planning to run semi slick tyres as well. So my question is what size after market wheels have people installed on the turbo model? Offset width pcd etc? Looking forward to some responses...
#2 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 04 November 2013 - 07:08 AM
If you like the style of what you have buy a set of rear wheels and put them on the front. Same tyres for front and back and more options?
#3 fezzasus
Posted 04 November 2013 - 08:21 AM
We have the same problem here with the front tyres (however not as bad as you), most people change to 16 inch alloys at the front which increases options.
Wheel fitments are:
7J x 16 5x110ET20 65.1 bore for fronts
7.5J x 17 5x110ET36 65.1 bore for rears
This allows the use of 195 x 45/50 x 16 tyres on the front, and standard 225 x 45 x 17 on the rears. We usually buy team dynamic 1.2 alloys as they are common here, however any place with a stock of blanks should be able to make you something.
Alternatively some Holdens may have the same PCD, so sourcing from 16 inch holden alloys for the front may be an option. A few members here use Vauxhall Astra alloys on the front.
Hard to do when there's only one VX in Oz. Plus handling is awful.
#4 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 04 November 2013 - 12:41 PM
Who said handling is awful? Mine handle pretty good.
#5 fezzasus
Posted 04 November 2013 - 12:48 PM
You'll get more tram lining, and less feedback close to the limit. null point though as there simply isn't another set of VXT alloys in Australia.
#6 chappers2000
chappers2000
  • 489 posts
  • Interests:Sports cars; kit cars, mountain biking
Posted 04 November 2013 - 01:27 PM
As said, could try some Holden alloys. I didn't want to go 16" on the front (though 195/50 tyre sounded good) as I have loads of local speed bumps to contend with. Had Team dynamics pro race 1.2 on my last car so didn't want those. for now just got some Vauxhall Vectra sri alloys 7x17 all round. Need spacers to correct the offset but for £240 for freshly refurbished alloys (+£60 for spacers/nuts as they are et+41) I couldn't say no. I think they look OK with Kuhmo ku39 205x45x17 front and standard 225x45x17 rear tyres.
#7 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 04 November 2013 - 05:20 PM
Looks good chappers!
#8 drpau
drpau
  • 1,899 posts
Posted 04 November 2013 - 05:34 PM
....Or you can go for 195 40 17 (elastic bands) or 195 45 17 which will go straight onto your 17" fronts. .
#9 drpau
drpau
  • 1,899 posts
Posted 04 November 2013 - 05:36 PM
#10 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 05 November 2013 - 01:26 PM
:yeahthat:
I have been running those for years thumbsup
#11 Aussievx220
Aussievx220
  • 33 posts
Posted 07 November 2013 - 02:43 AM
I'm thinking of getting some of these in 17 speedy carbine
#12 fezzasus
Posted 07 November 2013 - 10:37 AM
Just be wary of the front rubbing if you go for a wide rim.
#13 chappers2000
chappers2000
  • 489 posts
Posted 07 November 2013 - 12:18 PM
I like those. 17x7.5 with a 205x45x17 front and standard rear?
#14 Aussievx220
Aussievx220
  • 33 posts
Posted 09 November 2013 - 07:46 AM
So the factory pcd is 110 and 65.1 bore for standard vx220 turbo's?
#15 Rickwoo118
Rickwoo118
  • 5,800 posts
Posted 09 November 2013 - 12:32 PM
Yes, I like them a lot.
#16 chappers2000
chappers2000
  • 489 posts
Posted 09 November 2013 - 02:18 PM
Yes. 5x110 Pcd, 65.1mm bore, et+26 front, et+35 rear, though you might want to adjust the offset if changing from the 5.5 and 7.5" widths.
#17 .Adam.
.Adam.
  • 405 posts
Posted 09 November 2013 - 05:39 PM
Just for your information, when I changed to my current Compomotives on my Tubby, the sizes and offsets are:
[color=#1f497d;][font="calibri, sans-serif;"]Front et20 PCD 5x110 c/bore 65.1 7x17[/color][/font]
[color=#1f497d;][font="calibri, sans-serif;"]Rear et30 PCD 5x110 c/bore 65.1 8x17[/color][/font]
These have been fine in regards to fitment and rubbing.
#18 Aussievx220
Aussievx220
  • 33 posts
Posted 10 November 2013 - 05:12 AM
What tyres are you running on these wheels mate?
#19 .Adam.
.Adam.
  • 405 posts
Posted 10 November 2013 - 03:37 PM
I've got the standard Contis on the rears, and Kumho KU39 205/45 on the front. When the rears wear out I will get the same Kumhos, but maybe go a touch wider as the rims are a bit wider.
#20 chappers2000
chappers2000
  • 489 posts
Posted 11 November 2013 - 01:16 PM
[color=rgb(31,73,125);][font="calibri, sans-serif;"]Front et20 PCD 5x110 c/bore 65.1 7x17[/color][/font]
[color=rgb(31,73,125);][font="calibri, sans-serif;"]Rear et30 PCD 5x110 c/bore 65.1 8x17[/color][/font]
 and very nice they look too. thumbsup
