have you considered using the x22xe Vauxhall Omega / Frontera bottom end to create a 2.2 turbo
IMO, the longer stroke isn't ideally suited to a turbocharged engine really as it promotes torque and also that will reduce the rev limit (which wont be a problem on a KKK04 turbo, but would be on a mid sized turbo).
The price of a brand new Z20LEH is only £2500 when I last checked, not too bad really.
£2500 for a brand new LEH Where from? My vauxhall dealer quoted me several multiples of that!
Yea, I was a bit surprised as well, I did try and make sure he was quoting for a Z20LEH (as opposed to a Z20LET), but he sounded a bit thick, so maybe he made a mis-quote. I rang up my local main Vauxhall (
http://www.drivevaux...hipDetails.aspx) dealer in Bristol approx. 2 months ago just to get a feel for the price. If you ring up, see if they can discount for 2 pls.
The key advantage is those brilliant Z20LEH pistons (in brand new bores), they are far better than people give them credit for. They are forged well enough to easily cope with 500 BHP (probably 600+ in reality) and they have a high silicon content (12%) which means they don't expand much, so the OEM piston to bore clearance is nice and tight (way better than the Omega pistons I currently have).
Edited by Nev, 11 January 2014 - 08:04 PM.
