Smiley said this in another thread:
Both oem ecu and obdtuner start dialing back ignition as from 57 degrees celcius temp.
One of the dutch drivers asked Peter to tone that down a bit at zandvoort this year, but it's in there as a safety precaution, so left in there as default.
If you feel like you will be hitting high temps, you need to consider water injection. (on hot days, the dual pass mod, large header tank and very expensive max size pro alloy prerad is not helping one bit)
Maybe leevx's new manifold design also helps. Time will tell.
By the time you hit 90 degrees, you will have lost about 50 bhp....isch.
SO, this has got me thinking, (assuming smiley is right?)
This is saying that at regular high supercharger use (WOT etc) the Pro Alloy prerad/laminavo set up does not cool the manifold sufficiently to keep the intake temps down. The answer is to water cool the intake to solve this or redesign the cooling system.
Questions?
1. Could you not just run without a prerad (stage 1 style) and water inject? Obviously you would go through quite a bit of water?
2. If you are use water inj what size pre rad would be optimal ? would a smaller pre rad mean using more water or is the limiting factor the laminavos so a smaller pre rad (chiquchento/mocal?) would make very little difference?
If my thinking is completely wrong please educate me but If I run water inj with a smaller pre rad vs a pro alloy would I really be losing out or would we have to take some intake measurements to find out?
Cheers Deano
